2015+ Brake Caliper Question "Brembo"
Curious if anyone knows if the front 4 piston Brembo Caliper off a Focus RS would fit a 2015-2021 EDGE. The Focus has the same bolt pattern as the Edge and I know the factory front Edge rotor is 345mm. Now with that being said, Ford Performance makes a upgraded Vented rotor like my 2019 EDGE ST that is 347mm or 13.7" that will fit the factory 4 piston brembo caliper. Now I am not looking to fit a focus Rotor on the vehicle but more so utilizing the Caliper up front in conjunction with our 345mm rotors.  Not sure if the caliper mounting bracket is the same spacing. If not I can always make a bracket adapter to fit . Just kicking ideas since you can get the front calipers dirt cheap....
