Serpentine Tensioner bearing ?
Audrazas
6 hours ago, Audrazas said:
Hi. Maybe someone can tell me what are the dimensions of the serpentine belt tensioner bearing?  I have problems with parts in my country.
I doubt anyone here has disassembled the tensioner to confirm the bearing number, so best you disassemble yours  and have an industrial bearing supplier match it up.
Are referring to a BT4Z-6B209-B?
Have you tried from a Ford dealership in your country?
Edited by enigma-2
No I didn't. It was an easy job. The work lasted maybe half an hour to took the tensioner of and measure a bearing. Now I can say if someone needs that dimensions is 70mm height 25mm width and 17mm center. Thanks for trying to help me :) one more question. how often you change gearbox filter or it's unnecessary to do that ?
Edited by 1004ron
  • 1004ron changed the title to Serpentine Tensioner bearing ?
