DRL = low beams??
Cebj
So on the 2015 base model Edge SE headlights, is it normal for the low beams to be the same brightness as the daytime running lights? I have noticed since purchase that the low beams are inadequate, but now I have noticed, when I have the headlights on automatic, as I pull into the garage, there is absolutely no change from the brightness of the DRL’s and when the low beams allegedly turn on. The only way I can tell they even come on per se is because the dash lights turn on.
Edited by Cebj
