Edge 2018 Factory Code for Keyless Entry
I have a 2018 Edge SEL.   I need to locate the Factory code for the keyless entry on the post by the drivers door.  I have watched many YouTube videos and read many forums but none were really for the 2018 Edge and the locations of the sticker does match what I have.  Does anyone know how i can find this information?    Thank You.
Having just been through this, I can confirm that it would take an act of congress to get this from Ford Corp.
The two options:  find in in the pouch containing the owners manual, or on the electronic module near the drivers left leg.
If you have both keys, there is a method to show the factory code on the instrument cluster.
The instructions are in the owner's manual.
Quote
Displaying the Factory-Set Code
Note:   You need to have two programmed intelligent access keys for this procedure.
Missing Image
  1. Open the floor console storage compartment lid.
Missing Image
  1. With the buttons facing the rear of your vehicle and the key ring up, place the first intelligent access key into the backup slot inside the center console.
  1. Press the START/STOP button once and wait a few seconds.
  1. Press the START/STOP button again and remove the key.
  1. Insert the second programmed key into the backup slot, then press the START/STOP button.
The factory-set code appears in the information display for a few seconds.
Note:   The code may not display until after any other warning messages first display.
Edited by omar302
