Best GTDI oil to use and when to change?
DrivingofftheEdge
You want SN+ oil (or SP) in your turbo engine, these oils are made for use in forced induction engines.
5W30 minimum, though 10W30 might work with lower volatility and better resistance to fuel dilution/shear.
Full synthetic of course for normal oil change intervals, anything you can get off Walmart shelves or online should be adequate.
Now if you are a full throttle type driver, there are "better" oils out there, but you have to pay the $$$.
  • 3 years later...
  On 12/12/2024 at 6:45 PM, IWRBB said:
I change the oil in all my cars every 5000 miles.  Time does not matter to me.
Expand
100% agree. I put lots of miles on per month, my 2019 is at almost 100,000 miles now. I change at 5000 miles or less, use synthetic and use a factory filter. Plugs are very clean, combustion chambers are clean (looked with a small camera), and performance is great. Doesnt burn oil (or coolant).
Leaving any oil in for 8, 10, 12 thousand miles is asking for trouble. Synthetic or not, no oil can magically deal with fuel dilution and the amount of dirt and combustion by-products that a hard working little turbo engine produces.
Saving 50 bucks per change does not pay for an early failed engine.
