fordedgenashvilletennessee Posted February 25, 2021 Report Share Posted February 25, 2021 I have a 2015 Edge with the EPS. I am trying to change my rear pads. I can not get the left caliper piston to retract, even with the EPS maintenance mode. I have put it in maintenance mode and used a C clamp and a brake compressor tool and it is rock hard and won't go back in. Any suggestions? Quote Link to comment Share on other sites More sharing options...
lildisco Posted February 25, 2021 Report Share Posted February 25, 2021 (edited) On my 2016, it's not compressed, it needs to be turned to get the piston back in. Believe that there's a special tool that will make your life easier. Looks like a cube with different extensions on it to fit in the piston & ratchet it back. https://shop.advanceautoparts.com/p/lisle-disc-brake-piston-tool-28600/25961363-p?product_channel=local&store=6997&adtype=pla&product_channel=local&store_code=6997&gclsrc=aw.ds&&gclid=EAIaIQobChMI9M240eiD7wIV1YtaBR0DgQ6wEAQYASABEgJkYPD_BwE Edited February 25, 2021 by lildisco 2 Quote Link to comment Share on other sites More sharing options...
1004ron Posted March 2, 2021 Report Share Posted March 2, 2021 On 2/24/2021 at 7:09 PM, fordedgenashvilletennessee said: I have a 2015 Edge with the EPS. I am trying to change my rear pads. I can not get the left caliper piston to retract, even with the EPS maintenance mode. I have put it in maintenance mode and used a C clamp and a brake compressor tool and it is rock hard and won't go back in. Any suggestions? Was lildisco suggestions any help? Quote Link to comment Share on other sites More sharing options...
lildisco Posted March 5, 2021 Report Share Posted March 5, 2021 I can confirm that the 2020 rears are also screw in style 1 Quote Link to comment Share on other sites More sharing options...
dolsen Posted March 5, 2021 Report Share Posted March 5, 2021 My 2015 also has screw in calipers. I just replaced the rear brakes on mine about 2 weeks ago. 1 Quote Link to comment Share on other sites More sharing options...
kizite Posted March 10, 2021 Report Share Posted March 10, 2021 My 2011 is also screw in. But one of mine i couldn't get to screw in all the way, ended up having to replace the caliper. Quote Link to comment Share on other sites More sharing options...
