artaura Posted February 8, 2021 Report Share Posted February 8, 2021 I located the factory code for my 2013 Edge Sport (on the label stuck to the fuse box) but have not been able to change the code to my personal code. I think I'm following the correct process, beginning with the doors in locked position: 1. enter factory code 2. press 1/2 key briefly 3. enter personal code 4. press 1/2 key for two seconds 5. nothing happens What am I doing wrong? Quote Link to comment Share on other sites More sharing options...
akirby Posted February 8, 2021 Report Share Posted February 8, 2021 Does the factory code actually work? Sometimes the digits are backwards. Did you try your new personal code after programming? Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted February 8, 2021 Report Share Posted February 8, 2021 (edited) Think you may have glossed over the correct procedure. I did the same thing first-time I tried. Try by following these directions exactly: 1. Enter the factory-set code. 2. Press the 1•2 on the keypad within five seconds. 3. Enter your personal 5-digit code. You must enter each number within five seconds of each other. 4. For memory recall feature, enter the sixth digit 1•2 to store driver 1 settings or 3•4 to store driver 2 settings. 5. The doors will lock and then unlock to confirm that programming is complete. Example: assume your factory code is 12345 and your personal code is 11335. Then enter: 12345113351 one after the other and it should take. Edited February 8, 2021 by enigma-2 Quote Link to comment Share on other sites More sharing options...
