Best EDGE Windshield Wipers from Canadian Tire?
Apparently the 2020 Edge has a unique clip for the front wipers. Canadian Tire (CTS) has a set of Reflex 28" x 2 wipers (021-1923-A12) "apparently" specifically for the EDGE. Has anyone used them or any other wipers from CTS ie Michelin, Bosch? My manual is no hep whatsoever yet its a very common user item. I like to have a spare set for when a wiper flies off while on a long trip and away from stores. (I prefer CTS over going to an expensive dealer.)
Expand
What did you end up deciding on?
Personally I prefer Tryco or Bosch. Tryco used to be Ford OEM for years and years, but have no idea what Ford is sourcing now.
From what I've read, the 2020 has gone to a 28" (both l&r) pinch strip mount. You should be able to find this type mount on all brands. If CTS has Bosch, I'd go with them. Bosch has a reputation for long life. Just clean & treat the blades with 303 protectant a few times a year and the rubber will last 2x.
  On 2/6/2021 at 2:37 AM, enigma-2 said:
You can help your blades last (much) longer by wiping each rubber blade with a alcohol lens wipe (to clean off dirt, oils and the like)  and then spray and wipe with 303 Protectant.
(Its the ozone and UV sun rays that kills rubber parts and turns them hard).
Expand
Exactly what I do.  I have a 2016 Edge, 5 years of ownership in southern Alabama, and still has the original wipers.
