caveman315 Posted January 20, 2021 Report Share Posted January 20, 2021 Purchased used 2013 edge. no navigation card, so used car lot got me the version A11. Edge does not see sd card. Did hard reset no help. Sync says I updated sync correctly to version 3.1 and no help. Check the wiring at sd slot, everything seemed good. Put card into laptop and computer sees card ok and files on card. Any suggestions? Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted January 21, 2021 Report Share Posted January 21, 2021 Couple of ideas. 1. Is the SD card OEM? Cloned cards don't work properly as they are encrypted with a special key that the system can read, but prevents cloning them. 2. Other easy fix that was talked about, was a loose connector on the SD card socket. Quote Link to comment Share on other sites More sharing options...
akirby Posted January 21, 2021 Report Share Posted January 21, 2021 4 hours ago, caveman315 said: Purchased used 2013 edge. no navigation card, so used car lot got me the version A11. Edge does not see sd card. Did hard reset no help. Sync says I updated sync correctly to version 3.1 and no help. Check the wiring at sd slot, everything seemed good. Put card into laptop and computer sees card ok and files on card. Any suggestions? What does it say in the upper right? If it says information you don’t have nav. Quote Link to comment Share on other sites More sharing options...
caveman315 Posted January 21, 2021 Author Report Share Posted January 21, 2021 it says information Quote Link to comment Share on other sites More sharing options...
caveman315 Posted January 21, 2021 Author Report Share Posted January 21, 2021 the car is a 2013 Edge Limited with package 300A Quote Link to comment Share on other sites More sharing options...
caveman315 Posted January 21, 2021 Author Report Share Posted January 21, 2021 is there a way to add navigation to a non navigation unit. is there a software download? thanks Quote Link to comment Share on other sites More sharing options...
omar302 Posted January 21, 2021 Report Share Posted January 21, 2021 @caveman315 See this thread on XDA. 1 Quote Link to comment Share on other sites More sharing options...
