Sameer Posted January 17, 2021 Report Share Posted January 17, 2021 Hi, Got check engine light yesterday. Getting P1450 code when did diagnostic test at auto zone. Upon research from many article found that it could be the purge value issue, but i don't see the symptoms of it which says "trouble starting the car after fuel filling". Mine starts perfectly fine after filling the gas. What could be the possible fix? Appreciate the responses. Thanks. Quote Link to comment Share on other sites More sharing options...
akirby Posted January 17, 2021 Report Share Posted January 17, 2021 Doesn’t always cause issues. Mine was just the code. Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted January 18, 2021 Report Share Posted January 18, 2021 Pulled this off the web. " If everything seems in good shape, then you may have to take the vehicle to a certified technician. Majority of the tests performed for this code are done with a wide array of diagnostics tools. Error Code P1450 means the fuel tank is unable to bleed up fuel tank vacuum, and this has nothing to do with the fuel pressure sensor at the engine. The most common cause of this code is simply a defective Fuel Tank Pressure (FTP) sensor)." Quote Link to comment Share on other sites More sharing options...
Sameer Posted January 18, 2021 Author Report Share Posted January 18, 2021 3 hours ago, akirby said: Doesn’t always cause issues. Mine was just the code. So what you did to solve the check engine light. Quote Link to comment Share on other sites More sharing options...
akirby Posted January 18, 2021 Report Share Posted January 18, 2021 23 minutes ago, Sameer said: So what you did to solve the check engine light. Replaced the purge valve. Quote Link to comment Share on other sites More sharing options...
Sameer Posted January 18, 2021 Author Report Share Posted January 18, 2021 What the part number for my model and from where can i buy it? Quote Link to comment Share on other sites More sharing options...
Sameer Posted January 18, 2021 Author Report Share Posted January 18, 2021 Replaced the purge valve under hood this morning, but still having check engine on dashboard even drove for 4miles appx after replacing. Please suggest. Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted January 19, 2021 Report Share Posted January 19, 2021 did you clear the code and see if it came back? Quote Link to comment Share on other sites More sharing options...
mbritten Posted June 14, 2021 Report Share Posted June 14, 2021 Code didn’t clear right away for me either, it was showing as permanent on the code reader, I cleared the ones I could (pending and don’t remember what the other way) anyway, once you clear the codes you can with the reader. You need to start the car, let it idle for about a minute, then get on the highway and drive for 10 mins between 45-65mph. I just set my cruise to 64 and drove. After 10 mins park somewhere and let it idle for about another minute before turning it off. Turn it back on and hopefully light will be off. Found those instructions on some Ford site, worked for me. 1 Quote Link to comment Share on other sites More sharing options...
