Activating factory remote start
  On 1/14/2021 at 4:34 AM, jmr061 said:
What module did you find under the dash?  Gotta know the hardware you have first.
Expand
This guy
ft4j-19g367-aa
He has a t-harness that is connecting him to the obd controller behind the steering wheel where you connect an aftermarket system like 12volt solutions.
I'm assuming this is also what keeps setting off my alarm, I see there is a sensitivity adjustment knob on it that I need to turn down...
Yup that is the VSS or Vehicle Secirity System that has a built in shock sensor.  It only allows remote start if there is an antenna plugged into it (should be mounted on the windshield) and then a seperate remote start only fob is used.  So you would have two fobs, the remote start and the oem keyless.
https://accessories.ford.com/vehicles/edge/2017.html?cat=391
  • 2 months later...
