Oliver_951 Posted January 11, 2021 Report Share Posted January 11, 2021 Hello there... I would like to ask for some help with my 2013 Ford Edge's P0455 fault code. Yesterday my service engine soon light turned on and today I ran a test "for first time" with my recently purchased Foxwell NT510 Elite Multi-System Scanner. The scanner threw the P0455:00-EC and P115E:00-6C error codes. Is there someone who has had these error codes in their 2013 Ford Edge SEL 3.5 who can tell me a fixing tip ? Thank you very much in advance... Rgds, Jorge U. Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted January 18, 2021 Report Share Posted January 18, 2021 The P0455:00-EC code means Missing or loose fuel cap Incorrect fuel filler cap used Fuel filler cap remains open or fails to close Foreign matter caught in fuel filler cap EVAP canister or fuel tank leaks EVAP system hose leaking Fuel tank leaking And the P115E:00 code is related to carbon deposits around the throttle plate. When these deposits accumulate more than the PCM can compensate for. Its possible that you have two separate faults. 1 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted January 18, 2021 Report Share Posted January 18, 2021 Quote Link to comment Share on other sites More sharing options...
