Sage Posted January 9, 2021 Report Share Posted January 9, 2021 Ok, for my 2019 ST, are the Bilstein shocks really that much of an improvement over the stock setup? Looking for something that will help out with seems to be a top heavy Edge without getting into a big cost change. Thanks Quote Link to comment Share on other sites More sharing options...
Xtra Posted January 9, 2021 Report Share Posted January 9, 2021 (edited) The Bilstein shocks and struts I installed seemed to me to be a little bit softer than the stock set up on my 2016 Sport. They did help with weight transfer and reduced oversteer. Also for my car biggest difference and improvement in handling came with the H&R Springs. Edited January 9, 2021 by Xtra 1 Quote Link to comment Share on other sites More sharing options...
Sage Posted January 9, 2021 Author Report Share Posted January 9, 2021 ^^^^ thanks for the info ^^^^ Quote Link to comment Share on other sites More sharing options...
az_edge_st Posted June 17, 2021 Report Share Posted June 17, 2021 @Sage Did you ever get the Bilstein shocks and H&R springs installed. I also have 19’ Edge St and was thinking about doing the same if it’s worth it. Quote Link to comment Share on other sites More sharing options...
Sage Posted June 17, 2021 Author Report Share Posted June 17, 2021 I did not, I decided to keep my stock set up. Quote Link to comment Share on other sites More sharing options...
onyxbfly Posted June 17, 2021 Report Share Posted June 17, 2021 5 hours ago, az_edge_st said: Did you ever get the Bilstein shocks and H&R springs installed. I also have 19’ Edge St and was thinking about doing the same if it’s worth it. I heard that the STs are equipped with the Bilstein B4 equivalent. Take that with a grain of salt. I heard it on the nets and you get what you pay for. What I can attest to is that H&R springs make for a tremendous difference in handling and cornering. H&R springs with the Bilstein B6 will make your car handle like a go cart on steroids! I can not recommend the combo enough! Quote Link to comment Share on other sites More sharing options...
DcLars Posted December 19, 2022 Report Share Posted December 19, 2022 Onyxbfly... can you explain a little how the setup works? one shock n one spring mounted together? not sure. Quote Link to comment Share on other sites More sharing options...
