DougS Posted January 7, 2021 Report Share Posted January 7, 2021 I have a 2018 Edge Sport that I have had since new. I used to be able to lock and unlock using the handle of any door with the intelligent access system. Just recently I can only do this with the drivers door handle. If I try this with any of the other three doors it will not lock pressing on the ribbed area or unlock with my hand inside the handle. Is there a setting that I may of accidently changed that only allows this? I have looked through the owners manual, but cannot find anything reference making only the driver door work when using the intelligent access system. I just want to make sure I am not missing something before going to the dealer for a possible repair. Thanks. Quote Link to comment Share on other sites More sharing options...
Sage Posted January 7, 2021 Report Share Posted January 7, 2021 (edited) I am having the same issues, it is intermittent for me. I am thinking 2018/19 are the same setup. My ST is still under warranty and I have an appointment tomorrow to have it looked at. I will let you know what they say. Edited January 7, 2021 by Sage Quote Link to comment Share on other sites More sharing options...
Guest Sarsoor Posted January 8, 2021 Report Share Posted January 8, 2021 I’m having the same issue! Quote Link to comment Share on other sites More sharing options...
DougS Posted January 8, 2021 Author Report Share Posted January 8, 2021 Thanks, let me know what you find out. I guess mine is intermittent too, I tried them this morning after they weren't working for several days, and the other doors are working again. Quote Link to comment Share on other sites More sharing options...
Sage Posted January 8, 2021 Report Share Posted January 8, 2021 Ok, the tech could not duplicate the issue, but he worked on it for about 1 1/2 hours. The tech and advisor stated if it happened again, to bring it back and he will check all the scanners/sensors(?) in all the doors to see if he could find the issue. That will take a good part of the day, so they will get me home and back when they are done. I know it will happen again, just a matter of time. If any of you figure out out is going on, please post what was found. If I find out anything, I will post that info. As normal, would not do it when at the dealer. Quote Link to comment Share on other sites More sharing options...
DougS Posted January 9, 2021 Author Report Share Posted January 9, 2021 Thanks Sage. Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted January 10, 2021 Report Share Posted January 10, 2021 I read on the (think that it was the 150 forum) that moisture in the sensor played a role in not working. Quote Link to comment Share on other sites More sharing options...
DougS Posted January 10, 2021 Author Report Share Posted January 10, 2021 Yes, I have read that too about the moisture, as I have been doing some google searching on this issue and have seen on just about all of the forums for the different Ford models, people discussing this same issue with their handles. I did see one other post on I believe either an Explorer or Expedition forum, that a weak vehicle battery could cause this issue too. They said that if the system identifies that the vehicle battery is weak, one of things it does to conserve power is to turn off the sensors in all of the door handles except the drivers door. I don't know if that is it or not, but it makes sense. While I believe that my battery is probably ok if i drive it enough, my Edge does sit unused sometimes for several days, and even up to a week. I will have to pay attention to if this happens only after the vehicle sits for a while. Quote Link to comment Share on other sites More sharing options...
Sage Posted January 10, 2021 Report Share Posted January 10, 2021 (edited) ^^^^ Good point on the battery, as my ST sits most of the time. When I do drive it, it is for short drives. Now I am thinking of getting a new battery, or tender, or getting with the dealer on this possibility. ^^^^ Edited January 10, 2021 by Sage Quote Link to comment Share on other sites More sharing options...
akirby Posted January 10, 2021 Report Share Posted January 10, 2021 If it sits for more than a week get a battery tender. Otherwise get a ctek charger/conditioner and throw it on there a couple times a month. Quote Link to comment Share on other sites More sharing options...
Sage Posted January 10, 2021 Report Share Posted January 10, 2021 35 minutes ago, akirby said: If it sits for more than a week get a battery tender. Otherwise get a ctek charger/conditioner and throw it on there a couple times a month. I ordered a battery tender/auto charger this morning. Still might consider putting in a new battery, as mine is 27 months old and now it may not be up to specs since it sits a lot. Quote Link to comment Share on other sites More sharing options...
akirby Posted January 10, 2021 Report Share Posted January 10, 2021 2 hours ago, Sage said: I ordered a battery tender/auto charger this morning. Still might consider putting in a new battery, as mine is 27 months old and now it may not be up to specs since it sits a lot. . Get a Solar BA-7 or newer one to test it. Quote Link to comment Share on other sites More sharing options...
Sage Posted January 11, 2021 Report Share Posted January 11, 2021 I dropped it off with a different dealer. They will have it a couple of days to see if they can figure it out. Naturally it did not do it when I dropped it off, keeping my fingers crossed. Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted January 13, 2021 Report Share Posted January 13, 2021 Would be simple enough to run a CCA test on the battery to isolate its condition. Quote Link to comment Share on other sites More sharing options...
DougS Posted January 14, 2021 Author Report Share Posted January 14, 2021 I put one of my ctek chargers on my Edge, (I have a couple of old cars that I use them on over winter), and when it showed the battery was fully charged I removed it and checked the doors and all of them were working. I have recently needed to drive my car more, and I check the other handles each time I'm out and so far they work every time. Maybe there is something to the handle sensors in the "secondary" doors turning off if the battery is weak? Quote Link to comment Share on other sites More sharing options...
Sage Posted January 14, 2021 Report Share Posted January 14, 2021 Got my ST back from the other dealer. Basically they told me there are no codes and could not duplicate the issue. When I asked them if they would test the battery, they said there was no reason too. I have already made an appointment with a local mechanic to test the battery. He will also add the pig tail to hook up my battery maintainer, no extra change. Could not pass up that offer. 1 Quote Link to comment Share on other sites More sharing options...
Sage Posted January 19, 2021 Report Share Posted January 19, 2021 When I dropped off my ST with the local mechanic, I decided to have him put a new battery in. He also hooked up the pig tail for the battery maintainer, time will tell. Quote Link to comment Share on other sites More sharing options...
Perblue Posted January 29, 2021 Report Share Posted January 29, 2021 On 1/19/2021 at 7:11 AM, Sage said: When I dropped off my ST with the local mechanic, I decided to have him put a new battery in. He also hooked up the pig tail for the battery maintainer, time will tell. Did this fix it? I'm currently having this issue on my 2019. Quote Link to comment Share on other sites More sharing options...
Sage Posted January 29, 2021 Report Share Posted January 29, 2021 22 minutes ago, Perblue said: Did this fix it? I'm currently having this issue on my 2019. It has been two weeks and no issues so far. I will feel more comfortable in four weeks if everything is still working as it should. I will post an update around the middle of February. 1 Quote Link to comment Share on other sites More sharing options...
Sage Posted February 9, 2021 Report Share Posted February 9, 2021 (edited) Ok, I am at 22 days since replacing the battery in my ST. So far my door locks are working as they should. Edited February 9, 2021 by Sage 1 Quote Link to comment Share on other sites More sharing options...
Perblue Posted February 9, 2021 Report Share Posted February 9, 2021 4 hours ago, Sage said: Ok, I am at 22 days since replacing the battery in my ST. So far my door locks are working as they should. I just had mine replaced yesterday on warranty. It kept saying low charge on battery even after 2 5 hour trips the past week and a half. Also yesterday as soon as I parked it and got inside I received a message that it went into deep sleep. So took it in and sure enough the battery failed testing. After replacement the locks work and it no longer is smelling like it's running rich. So I guess if you aren't leaving your edge parked for extended periods of time and all but the driver's door doesn't work it's likely your battery is dieing. Quote Link to comment Share on other sites More sharing options...
Sage Posted February 17, 2021 Report Share Posted February 17, 2021 Ok, this will be my last update since I replaced the battery 30 days ago. I have not had any further issues with the door locks. Whenever I parked at the same/different locations, I locked and unlock from different doors each time getting out and back in. I also have purchased a battery maintainer and keep it plugged in when parked(my ST sits a lot). 1 1 Quote Link to comment Share on other sites More sharing options...
Guest Shiprock Posted March 12, 2021 Report Share Posted March 12, 2021 Thanks for this thread. 2019 ST and the driver's door only works for me now. Makes sense and I'll try to charge up the batter with a tender. If that doesn't work, I'll post. Otherwise, it sounds like this would be the solution. Quote Link to comment Share on other sites More sharing options...
Guest Pispa Posted April 1, 2021 Report Share Posted April 1, 2021 On 1/14/2021 at 4:11 PM, Sage said: Got my ST back from the other dealer. Basically they told me there are no codes and could not duplicate the issue. When I asked them if they would test the battery, they said there was no reason too. I have already made an appointment with a local mechanic to test the battery. He will also add the pig tail to hook up my battery maintainer, no extra change. Could not pass up that offer. There is a hook inside the door trim panel that is pushed out so it will not detect the key fob, if your passenger door vibrates while on high speed then that could be the issue too and low battery disables most of the car sensors even giving you the old chime when you turn on the car. Quote Link to comment Share on other sites More sharing options...
jdg0928 Posted November 17, 2022 Report Share Posted November 17, 2022 Glad you guys posted this info. I've been wrestling with this for a few months. My '19 Edge is at the dealer now. They told me Intelligent Access only works with the driver door, and I shut that down immediately. Anyway, I thought it might be correlated with rain and moisture, but that didn't seem to match when it would start and stop working. The battery, however, is far more likely. I don't drive much anymore and have been away for >7 days twice in the last six weeks. I would have never thought about it being the car battery, so they are testing it now. Quote Link to comment Share on other sites More sharing options...
