jocojim6996 Posted December 22, 2020 Report Share Posted December 22, 2020 is there any other motor that i can replace the 2010 ford edge sel 3.5l v6 with Quote Link to comment Share on other sites More sharing options...
onyxbfly Posted December 22, 2020 Report Share Posted December 22, 2020 Welcome to the forum, sorry to see that your first post is about a problem. Off the top of my head I believe the tranny is standard from 2010-2014. Your generation edge was available with 3 engine options: 2.0I4 Ecoboost 3.7 V6 Duratect engine(Edge Sport) and of course your original 3.5 V6 Personally I would go with the standard engine or the 3.7. you should be good to go with some small changes in programing to account for oil pressure and or small differences between the 3.5 and 3.7. HTH Good Luck. 2 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted December 22, 2020 Report Share Posted December 22, 2020 Any VCT based 3.5/3.7 is a plug n play motor for your 2010. The 2.0 did not appear in the Edge till 2012. So Edge, MKX thru 2010. Taurus, Flex, MKS, MKT, etc thru 2012 (switched to Ti-VCT in 2013). Mazda CX9 2007-2010 3.7 3 Quote Link to comment Share on other sites More sharing options...
onyxbfly Posted December 22, 2020 Report Share Posted December 22, 2020 28 minutes ago, WWWPerfA_ZN0W said: Any VCT based 3.5/3.7 is a plug n play motor for your 2010. The 2.0 did not appear in the Edge till 2012. So Edge, MKX thru 2010. Taurus, Flex, MKS, MKT, etc thru 2012 (switched to Ti-VCT in 2013). Mazda CX9 2007-2010 3.7 Thanks for the clarification Perf 1 Quote Link to comment Share on other sites More sharing options...
Scott Garner Posted January 5, 2021 Report Share Posted January 5, 2021 I am looking at local salvage yards for drop-in replacement engines, and I'm trying to find an authoritative list of compatible donor cars. I don't mind switching out some accessories or sensors as long as the thing is otherwise plug-and-play. I saw a post somewhere where someone said not to trust car-part.com as far as compatibility, so now I'm scared! I have a subscription to the Ford service manual site that expires tonight, but even there I don't see anything that says "this engine was used on 200x-20xx Edge/MKZ, and 200x-20xx Sable, etc." There's a local yard that has an engine from an 2009 Sable with less than 90k, and it doesn't cost as much as the others that are listed as coming straight out of an Edge, from the same yard. So I'm curious why that would be the case, since generally the prices of the engines seem fairly related to the number of miles on their chassis'. When I compare the specs of both engines, they are all identical (all the engine/piston/rod and head/cam/valve specs). Any help or advice is appreciated. Quote Link to comment Share on other sites More sharing options...
Waldo Posted January 5, 2021 Report Share Posted January 5, 2021 There are really only two different versions of the FWD based 3.5L, the iVCT and the TiVCT. The 07-10 Edge used the iVCT. The difference is the TiVCT has twin variable camshafts, the iVCT only has one. You can see the difference in the one vs two sensors on the valve cover. Other models that used the 3.5L IVCT include the 08-12 Taurus (and Sable), the 09-12 Flex, the 08-12 Fusion Sport and various Lincolns though some of them used the 3.7L version, which could also be used in your Edge. The F150, Transit and Mustang have also used versions of this engine, but since they are RWD based it would likely be more effort to get those to work properly though probably possible. 2 Quote Link to comment Share on other sites More sharing options...
Scott Garner Posted January 5, 2021 Report Share Posted January 5, 2021 Thank you, @Waldo. I'm not sure if it matters (?) but this Edge is AWD. Thanks for the tip about iVCT vs TiVCT. Mine in particular has only one solenoid per head, so I'm guessing that's iVCT. Is that Ford's analog to Honda's iVTEC vs VTEC? Quote Link to comment Share on other sites More sharing options...
Waldo Posted January 5, 2021 Report Share Posted January 5, 2021 The TiVCT didn't come out until 2011, so it's certain that you have an iVCT. Not sure how that compares to Honda. AWD doesn't matter, all of the AWD stuff is on the other side of the transmission and the control modules are separate. 2 Quote Link to comment Share on other sites More sharing options...
waynep Posted May 23, 2024 Report Share Posted May 23, 2024 (edited) What is the difference in two tooth timing chain and water pump and the single tooth engine. I purchased a used motor with two tooth and my is single tooth. Will it interchange in my 2010 edge. I have a 2010 edge, motor went bad and I got a used motor and went to replace water pump and chains and used motor is two tooth water pump and my is single tooth. Will is engine go in my 2010. Edited May 26, 2024 by 1004ron Keep it to one thread 1 Quote Link to comment Share on other sites More sharing options...
