Dmtaurus Posted December 21, 2020 Report Share Posted December 21, 2020 Since the 2.0 is a GTDI engine, has Ford come out with an approved method for cleaning it? Motor magazine as of 2017 said that any cleaning using typical cleaners should not be used on turbo engines at all, and this includes CRC brand GTDI cleaner that is spray into the intake system. Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted December 22, 2020 Report Share Posted December 22, 2020 the biggest fear is excess carbon chunking into the turbos after the cleaner lets them rip loose. ecoboosts generally do not suffer as badly as many other brands. BUT the wise thing to do is borescope the cylinders prior to an induction process. If done every 3 years/36K from mile 0, the risk is minimal. If you want to be sure tho ... If there is substantial buildup, best to do some kind of media blasting directly rather than induction cleaning. Quote Link to comment Share on other sites More sharing options...
Dmtaurus Posted December 27, 2020 Author Report Share Posted December 27, 2020 I use the OTC cannister unit and fuel injector cleaner, and induction system cleaner, on my naturally aspirated Taurus 3.5 and it works well. But with your answer on the induction part it sounds like a no-no and not the right solution. But now, I am curious about the need for, and the use of, OTC injector cleaner for using it on the direct injector set-up of this engine, if it should be done as routine maintenance. Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted December 27, 2020 Report Share Posted December 27, 2020 there is no proven "need" on ecoboost engines. but will it keep the valves clean? yes. will it prevent misfires due to carbon breaking off and disrupting combustion, or due to valves not closing completely? yes. definitely a routine maintenance item IF you want to go this route. if you are unsure, take it to a pro, or leave well enough alone. Quote Link to comment Share on other sites More sharing options...
