hholmesauto Posted December 19, 2020 Report Share Posted December 19, 2020 13 Ford Edge 3.5 l p0352 Coil Over Plug code. Changed plugs, coil pack, compression test ( avg. 160 every cylinder), tested wires to and from, also unrelated tested the Fuel injectors and the wiring and had computer reprogrammed. Erased after each, DTC P3502 returns. Any suggestions? I believe that the PCM or ECM is the problem. I think when the #2 coil over fried itself it also fried the circuit. Even though the wires check out. I could be wrong. That's why I' joined this board. Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted December 19, 2020 Report Share Posted December 19, 2020 yes, most likely the driver circuit is toast, and you need to have the pcm reprogrammed by a service such as circuitboardmedics.com how many miles when this code first popped up? how did the coil look when you pulled it out? any pics to share? Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted December 20, 2020 Report Share Posted December 20, 2020 There's also a possibility that the problem concerns the wiring running to the coil. Connection may be corroded or burned. Quote Link to comment Share on other sites More sharing options...
