convert FWD to AWD?
Jgrasham
I have found several topics of converting TO FWD, Has anyone converted FWD to AWD? I'm sure it is as "simple" as finding a AWD donor, and swapping in the parts, and I would think the electrical connections are already in the car. I just wanted to see if anyone has tackled it, and what to expect. Also thinking of a 2.3 swap if the 2.0 ever fails.
I've done more than a few FWD --> AWD swaps on DSMs, and let me tell you the only reason to do it, is if you have a massive personal attachment to the original car, or you cannot find a rust free AWD shell at all.  It requires about 10x than you would think.  You may even have to weld the rear subframe bolts and suspension may be entirely different.  If there's no spot for the rear diff, then you'll have to cut the rear floor pan out, and weld in one from the AWD vehicle.  Potentially brake lines, fuel lines are all different..etc.
And not to mention wiring, sensors, and everything else that may be different.
I'd honestly just buy a clean AWD Edge, try to find one with a blown motor or something.  Try to 2.3 swap it at the same time.  Win-win.
