Ridgeback Ray Posted November 21, 2020 Report Share Posted November 21, 2020 Hi Fellow Edger's Would anyone have any experience of a 2017 European model (not that it should make a difference on this issue) hub bearing failures ??? Had car since new and has been great, not a single issue. Now at 45,000miles and a droning on a wheel. Pretty sure this is a hub bearing fault as noise increases with road speed, not engine RPM. I have checked the play in the wheel and nothing obvious, either in the 12-6 position or 3-9 position. No vibration on steering wheel when driving and brakes work fine / no squealing. So I have ordered a replacement hub and chosen a SKF unit for £110. Ford wanted nearly £300 a unit to supply only. Anyone any idea of the correct torque for this hub ? Also for the rear incase the sound is travelling and it is a rear unit. Many thanks if you can advise. Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted November 22, 2020 Report Share Posted November 22, 2020 check the service manual available here https://drive.google.com/drive/u/2/folders/1wBzOTmEZvCvnzvmTI470QBGyYX60xDBh hope it is of help to you. and good luck! Quote Link to comment Share on other sites More sharing options...
Ridgeback Ray Posted November 22, 2020 Author Report Share Posted November 22, 2020 You absolute Legend !!! Thank you Quote Link to comment Share on other sites More sharing options...
