ik0n Posted November 1, 2020 Report Share Posted November 1, 2020 Hey all, We recently purchased a 2020 Edge and I was installing a hardwire kit for a dashcam. I have it installed, but I couldn't remove the a pillar trim (was worried about breaking it by pulling too hard, perhaps it needs to be slid?). The wiring is currently just tucked in behind the trim, but I would like to remove the trim to ensure it is out of the path of the airbag in there SHOULD the bag ever need to go off. Secondly, do you all just disconnect the positive terminal on the battery when doing electrical work on the car, since the neg terminal is almost impossible to get to without deciding to take out the entire battery? TIA. Cheers Quote Link to comment Share on other sites More sharing options...
ik0n Posted November 4, 2020 Author Report Share Posted November 4, 2020 No comments? I am surprised no one has removed the A-Pillar trim for some kind of electrical installation. I suppose I should just give it a go myself, hope I don't break anything and film it along the way to help others out. Quote Link to comment Share on other sites More sharing options...
omar302 Posted November 4, 2020 Report Share Posted November 4, 2020 See the attached file. It is fairly simple. APillar Trim Panel Interior.pdf 4 Quote Link to comment Share on other sites More sharing options...
ik0n Posted November 5, 2020 Author Report Share Posted November 5, 2020 That is great Omar! Thank you VERY much! Quote Link to comment Share on other sites More sharing options...
tpm419419 Posted January 11, 2023 Report Share Posted January 11, 2023 Just seeing this now. The upper piece cannot be removed without removing the lower 2 pieces?. Just trying to run wire at the base of the upper trim piece where it meets the dash. 2019 Edge Thanks Quote Link to comment Share on other sites More sharing options...
Jon051410 Posted January 31 Report Share Posted January 31 Do you also have the PDF available. I'm trying to do the same thing. 1 Quote Link to comment Share on other sites More sharing options...
1004ron Posted January 31 Report Share Posted January 31 On 11/4/2020 at 9:47 AM, omar302 said: See the attached file. It is fairly simple. APillar Trim Panel Interior.pdf 2 minutes ago, Jon051410 said: Do you also have the PDF available. I'm trying to do the same thing. What PDF are you looking for? 1 Quote Link to comment Share on other sites More sharing options...
Jon051410 Posted January 31 Report Share Posted January 31 That's the one thank you 1 Quote Link to comment Share on other sites More sharing options...
