2.0 Oil Pan Leak
scottyschafer
Hello,
It looks like i have a pretty healthy leak on the driver rear corner of the oil pan on my 2013 edge 2.0 ecoboost where is meets the engine block. I have not been able to find any information on changing the gasket on this engine. Generally oil pans are pretty straight-forward however i see this one seems to have bolts which go sideways into the transmission housing. Has anyone changed one of these and is there a specific tightening procedure do deal with the bolts going up into the engine and sideways into the transmission housing? Also what gasket did you use and did you run into anything unexpected?
Thanks for any suggestions.
