flymore Posted October 18, 2020 Report Share Posted October 18, 2020 2018 3.5L AWD Manual calls for motorcraft mercon lv transmission fluid of course but wondering if Valvoline Maxlife Multi-vehicle full synthetic would be good? Or is it best not to mix and just keep using motorcraft because a drain/fill won't get all the fluid out and it's best not to mix? Thanks Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted October 19, 2020 Report Share Posted October 19, 2020 best not to mix for the long term. mixing should be reserved for "top up" type work. No harm in sticking with Motorcraft LV fluid as long as you strictly observe the 5/60 rule of fluid exchange. If you are OCD, 2.5/30 is even better Quote Link to comment Share on other sites More sharing options...
flymore Posted October 20, 2020 Author Report Share Posted October 20, 2020 12 hours ago, WWWPerfA_ZN0W said: best not to mix for the long term. mixing should be reserved for "top up" type work. No harm in sticking with Motorcraft LV fluid as long as you strictly observe the 5/60 rule of fluid exchange. If you are OCD, 2.5/30 is even better 5/60? Is that 5 years 60,000 miles? Uhhhhhh OCD 2.5/30???? Not sure I've heard of that. Thanks Quote Link to comment Share on other sites More sharing options...
akirby Posted October 20, 2020 Report Share Posted October 20, 2020 35 minutes ago, flymore said: 5/60? Is that 5 years 60,000 miles? Uhhhhhh OCD 2.5/30???? Not sure I've heard of that. Thanks 2.5 years or 30k miles if you are obsessive compulsive about it. 1 Quote Link to comment Share on other sites More sharing options...
DaMiFo Posted October 20, 2020 Report Share Posted October 20, 2020 I agree with others here - for the long term, your best bet is to stick with Mercon LV. The trans fluid is not the issue, it's lack of changing it. Quote Link to comment Share on other sites More sharing options...
