omar302 Posted January 21, 2021 Report Share Posted January 21, 2021 PDF copy of @Gregertech post attached. Rear Camber Adjustment.pdf 3 Quote Link to comment Share on other sites More sharing options...
Frank Quiroga Posted October 27, 2024 Report Share Posted October 27, 2024 On 12/12/2020 at 1:07 AM, Gregertech said: Just a quick update, after being lowered for a couple of weeks, I started hearing random popping sounds coming from the right front, then a day or two later the left side started doing the same thing. I thought something was seriously wrong so I pulled the front tires and inspected everything to make sure nothing was loose. Turns out everything was fine and after some research online I had a good idea that it was the springs rubbing against the rubber seat. So I spent a good three hours pulling the front struts again and putting some grease between the springs and rubber spring seat. It's been about a week and no more noises from the front. Turns out doing this was mentioned in the how-to guide as an optional item. Unfortunately I didn't pay attention to it the first time. I forgot to mention, this time I picked up this oxygen sensor socket from Nothern tool to use on the 21mm nut on the top hat. Although I could only do about a quarter turn at a time It worked good. Performance Tool Oxygen Sensor Socket — 3/8in. Drive, Model# W1267 | Northern Tool I ma having the exact same issue! Same time frame as well. How is it so far?? Here is mine 2020 H&R springs. Alignment was a must. Overall really happy with it Quote Link to comment Share on other sites More sharing options...
