shift_enter Posted October 7, 2020 Report Share Posted October 7, 2020 (edited) around 20 & 140 mph on the speedometer the lighting is lower than the rest of the gauge. do I have a burned out bulb(s) or is this how it is on everyones? 2016 SEL Edited April 6, 2022 by shift_enter Quote Link to comment Share on other sites More sharing options...
onyxbfly Posted October 7, 2020 Report Share Posted October 7, 2020 Not sure what the exact issue but I can definitely tell you that it is not normal. Depending on your level of handyness you may be able to replace the bulbs. But I can tell you without a doubt that you can swap the entire IPC out in 20-30 minutes. 1 Quote Link to comment Share on other sites More sharing options...
