ToeNuttz Posted September 28, 2020 Report Share Posted September 28, 2020 2017 Edge Ti 2.0L shows P0304. The spark plugs were changed and I swapped ignition coil 4 to 1 spot. The code was cleared and 2 days later it popped up again, same code. Could my next target be my fuel injector? Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted September 28, 2020 Report Share Posted September 28, 2020 Although not typical for a coolant related issue, have you been tracking coolant level in the reservoir/degas bottle? If it has been steadily and appreciably declining, you could have a problem. How many miles do you have on your 2017? Fuel injectors should set P020x codes, but they typically come late in the day for GDI injectors. I have seen many fail without an error code being set. So is it possible? Yes. If you change 1 injector, change them all. Quote Link to comment Share on other sites More sharing options...
ToeNuttz Posted September 28, 2020 Author Report Share Posted September 28, 2020 2 hours ago, WWWPerfA_ZN0W said: Although not typical for a coolant related issue, have you been tracking coolant level in the reservoir/degas bottle? If it has been steadily and appreciably declining, you could have a problem. How many miles do you have on your 2017? Fuel injectors should set P020x codes, but they typically come late in the day for GDI injectors. I have seen many fail without an error code being set. So is it possible? Yes. If you change 1 injector, change them all. I have not been tracking the coolant level. My Edge is just shy of 70K. Just like spark plugs, change one you change them all. I have not looked into the replacement of the injectors yet. What would this typically run as far as cost and time to do it myself? Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted September 28, 2020 Report Share Posted September 28, 2020 IDK how much time it would take, but repairpal estimates 4-500$ in labor costs, so 4-5 hrs for a pro to do it. https://repairpal.com/estimator Usually some additional small parts are required to be replaced with these injectors, so you will need to grab a copy of the factory procedure. Cost - about 250+shipping/taxes https://www.rockauto.com/en/catalog/ford,2015,edge,2.0l+l4+turbocharged,3310416,fuel+&+air,fuel+injector,6224 Quote Link to comment Share on other sites More sharing options...
Coach JLo Posted December 19, 2024 Report Share Posted December 19, 2024 I'm having the same issues with my 2018 Ford Edge. It has a little over 70k miles, I keep getting a P0304 code even after new plugs and coil pack. I did notice the engine coolant level lower than the minimum just a week ago and refilled it. What could that mean? Coolant getting into the cylindar? Was the problem on the Edge above ever resolved? Thanks! Quote Link to comment Share on other sites More sharing options...
