tkw Posted September 26, 2020 Report Share Posted September 26, 2020 I've been stuck in a wheelchair for the last 20 some years. When I drive, I have to take my chair apart and pull it across my lap to put it on the passenger seat. I recline the seat so I don't get hung up on the steering wheel. My 2013 Edge drivers seat will recline all the way until it hits on the back seat. I don't think there is an actual limit, it sounds like unless I let off the switch the motor would keep turning. On my 2019, it seems like it will only go about 3/4 of the way back then it stops on its own - I am wondering if there is any way at all to adjust the limit on the recline so it will go back a little further? Quote Link to comment Share on other sites More sharing options...
onyxbfly Posted September 26, 2020 Report Share Posted September 26, 2020 33 minutes ago, tkw said: I've been stuck in a wheelchair for the last 20 some years. When I drive, I have to take my chair apart and pull it across my lap to put it on the passenger seat. I recline the seat so I don't get hung up on the steering wheel. My 2013 Edge drivers seat will recline all the way until it hits on the back seat. I don't think there is an actual limit, it sounds like unless I let off the switch the motor would keep turning. On my 2019, it seems like it will only go about 3/4 of the way back then it stops on its own - I am wondering if there is any way at all to adjust the limit on the recline so it will go back a little further? Unfortunately the 2015+ models will not recline all the way back or fold forward all the way. Quote Link to comment Share on other sites More sharing options...
tkw Posted September 26, 2020 Author Report Share Posted September 26, 2020 Thanks for the info. Since I wasn't able to test drive it before I bought it (I had to have hand controls installed afterwards) there are a ton of little things that I never thought to check into. Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted September 27, 2020 Report Share Posted September 27, 2020 You might consider contacting your local dealer to see what (if any) seat reclinning modifications are available. Ford offers a wide range of structural and nonstructural options for persons with disabilities. Its possible that one of the seat options they offer might be a modified reclining seatback. Quote Link to comment Share on other sites More sharing options...
