Jam157 Posted September 23, 2020 Report Share Posted September 23, 2020 2010 ford edge limited lights and gauges flashing and jumping information screen flashing. My first thoughts was bad ground or alternator anyone have this problem fixed? Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted September 25, 2020 Report Share Posted September 25, 2020 (edited) First pull the codes. There are several trouble codes associated with the instrument cluster and with so many feeds into the IC its impossible to guesstimate stuff out. When it next happens, try "wiggling" the key in the ignition switch. Fuse #27 feeds through the ig switch to the IC. Possible bad contact in the ig sw. Also check fuses #26 & #29 for corrosion. Both feed the IC. Grounds (power and logic) and difficult to get to and you'll need electrical schematics to find them. ?Pull the codes? Edited September 25, 2020 by enigma-2 Quote Link to comment Share on other sites More sharing options...
