@tmarsh
Any update on the cooled seats?
I have done some research and found that even though the 2019/2020 Edge use the same TEDs (link to bottom & back parts) and same SCME (link to part), the 2019/2020 have extra blocks in the ABD. So there seems to be a software/firmware update for the SCME, I have an old ForScan 2.4.0 version (Jan build) but there is no firmware flash option for the SCME.
Maybe someone with a 2019/2020 Edge with cooled seats can get temperature readings for the TEDs and see if they are better.
Note: The yellow boxes and red text are to highlight the 2018 changes compared to mine.
Edited by omar302
No info yet. I plugged in and checked the programming and it had been changed back to the original 2015 ABD. So I changed it back to that of the MkX where I know it worked great. Temps lowered some, but still I feel nothing on the seat back. Noticable difference on the bottom though it gets colder quicker, and fan speed is noticeably higher. My next step is to pull up the upholstery and make sure everything is connected going into the seat. I’ve been on vacation so haven’t done much.
  On 7/10/2020 at 7:35 AM, omar302 said:
@tmarsh
Expand
Aren't the 19 and ups heated and ventilated seats only?  Thought they removed the cooling part meaning it just shoot air through the seat rather than cooling the air when in ventilated mode?
Expand
Checking the 2020 Edge brochure (online) the heated/cooled seats are available as part of the 301A option package on Titanium, the 401A package on Titanium Elite and 401A (pictured) for ST.   Without the packages the Edge gets heated seats only.
Expand
Thats probably a typo.  The owner's manual states ventilated seats and I believe the service manual does as well.  Ford abandoned cooled seats cause they didn't work well.
Expand
I know they did change them starting with the 2018 F-150, but the parts listing for a 2020 Edge ST still shows the same TED part numbers as earlier models.
https://www.tascaparts.com/auto-parts/2020/ford/edge/st-trim/2-7l-v6-gas-engine/body-cat/front-seat-components-scat
They are definitely cooled (from the TED) not just ventilated.  Mine work fine in my 2015 F-150, my 2018 Edge and my 2019 Edge.  The only change I'm aware of over the years is Ford did something to the TED's fan/ducting, because I can hear it in the Edge's but not in the F-150.  F-150 forums have lots of complaints about the cooling not working, or the seatback even getting hot.  I must be lucky, mine works fine.  I had a 2015 Lincoln MKC and it neither heated nor cooled well, but I always attributed that to the thicker seat padding?
Edited by todd92
  On 7/11/2020 at 11:27 PM, akirby said:
I don’t think they changed the design - the same TED that heats the seats also cools them.
I think Ford just changed some of the wording to prevent customer complaints when they don’t cool well.
Expand
I've inspected my seats. No TEDs, no socks. And they definitely don't cool well. So same lousy performance but less parts.
Expand
On the F-150 they changed the design starting with the 2018 model. F-150Forum has a thread on the cooled seat fix issue & the new mechanism is pictured in this post.
Expand
The 2019 Nautilus Parts listing does show the new blowers. So maybe they only changed them on the Nautilus and not on the 2019 Edge, related to the new for 2019 availability of 22 way adjustable seats and hence the redesign of the seats and new blowers, while the Edge still kept the same seats (minor cover changes).
  • Thanks 1
Expand
Thanks for confirming. Performance benchmark is low on the new setup but at least it shouldn't diminish.
Okay I stand corrected...the 2020 edge does have cooled seating.  I pulled this from the service manual:
Climate Controlled Seat Operation
The driver and passenger climate controlled seat buttons are selected from the FCIM. The climate controlled seat system functions independently from the vehicle's climate control system.
The seat cushion and backrest are each equipped with a blower motor assembly. As cabin air is drawn through each blower motor, a Thermo-Electric Device (TED) heats or cools the air, which is then directed into the foam pad where it is distributed along the surface of the cushion and backrest of the seat. Once the system is activated, the SCME uses a set of flexible algorithms to control the heating/cooling modes and the blower speed dependant on the commanded climate controlled seat settings.
The SCME monitors seat cushion temperature while it supplies voltage and ground to both blower motors. The SCME also supplies a variable voltage signal to control the blower speed. Cabin air enters the blower through an integrated filter attached to the blower motor housing. Heated or cooled air exits the blower motor and flows through the foam pad.
Climate Controlled Seat Heating Characteristics
  • In heat mode, the blower motor can add up to 40–60° C (72–108° F) to the ambient inlet air temperature.
  • The system control settings are indicated next to each climate controlled seat heat switch button. The first setting is HIGH (3 indicators), the second setting is MED (2 indicators) and the third is LOW (1 indicator) then OFF (no indicators).
  • When heating, the SCME varies the speed of the blower motors and the duty cycle of the integral Thermo-Electric Device (TED) in order to reach and maintain the desired temperature determined by the system control settings.
Climate Controlled Seat Cooling Characteristics
  • In cool mode, the blower motors can remove up to 8° C (14° F) from the ambient air temperature entering the system.
  • The system control settings are based on the 3 indicators next to each climate controlled seat cool switch button. The first setting is HIGH (3 indicators), the second setting is MED (2 indicators) and the third is LOW (1 indicator) then OFF (no indicators).
  • When cooling, the SCME maintains a constant blower motor speed and a constant Thermo-Electric Device (TED) supply voltage (duty cycle is determined by the switch setting) in COOL mode.
Climate Controlled Seat Recovery Mode
NOTE: The presence of overtemperature faults (Diagnostic Trouble Codes (DTCs) B1153:4B, B1154:4B, B1151:4B and B1152:4B) can be induced by incorrectly operating the climate controlled seat system after an initial heat setting has been attained. If a heat setting is repeatedly turned off and on in an attempt to increase the seat temperature or repeatedly toggled between heat and cool modes, an overtemperature condition can result and the Diagnostic Trouble Codes (DTCs) may be set.
If the temperature of one of the blower motors rises above 110° C (229.8° F) in the heat mode or 65° C (148.9° F) in the cool mode for more than 4 seconds, the SCME records an overtemperature DTC, removes voltage from the Thermo-Electric Devices (TEDs) (part of the blower motor assembly) and goes into recovery mode (blower only) for 30 seconds to cool down the blower motor. The same occurs if a temperature difference of 60° C (108° F) or greater is detected between the backrest and cushion blower motors on either front seat. The SCME continues to monitor the blower motors while in recovery mode. If the temperature of the Thermo-Electric Devices (TEDs) do not drop to 105° C (220.8° F) in the heat mode or 60° C (139.9° F) in the cool mode after 30 seconds, the system continues to cool the blower motors in recovery mode for up to 5 minutes. If the Thermo-Electric Devices (TEDs) cool down after 30 seconds, but before 5 minutes (checked at 4 second intervals), the system is operating normally. An overtemperature DTC is still recorded even if the system recovers and is operating normally. This is more likely to occur during extreme cabin temperatures with significant seat back sun load. If the system does not recover within 30 seconds in heat mode or within 5 minutes in cool mode, the SCME disables that seat (fault mode) and remains off until the ignition is cycled. Also, if the SCME detects a temperature differential fault twice during the same ignition cycle, the SCME disables the seat. When a fault causes a shutdown, the climate controlled seat indicators turn off and that seat is not operational until the next ignition cycle.
Edited by jmr061
Expand
I had earlier went through As Built Data for a 2019 MKX and a 2018 F-150, both with ventilated seats, and the ABD blocks structure look similar to the 2019 Edge I poster earlier (with the additional blocks), so I was thinking it might be ventilated only after all, until your post proving they are still cooled.
Can anyone who upgraded from a 2016-2018 Edge with cooled seats to a 2019-2020 Edge with cooled seats confirm their experience?
  • 2 months later...
  • 1004ron changed the title to Cooled Seats
Congrats and welcome to the forum. Unfortunately the ventilated seats are hit or miss. Other times they leave a lot to be desired....namely your satisfaction. If  you're still within the 3year 36k warranty take it to your dealer. Maybe they can shed some light on the situation.  There is a TSB on it. Some users reported success, others not so much.
tsb15-0154.pdfFetching info...
If you are DIYer you can order the repair kit from this site and follow the directions. AMore thana few suers on the F150 forum have reported success utlizing this repair.
Seat Guru
Edited by onyxbfly
  • 3 years later...
Hi Everyone,
I am noticing an anomaly with my 2024 Edge ST's cooled seat functionality and how the vehicle's Auto Start/Stop system is impacting it.
Often, when the start/stop system turns the engine off in traffic, the cooled seat fan also stops working (but the indicator still says it's "on" in the HVAC screen).
If I toggle the cooled seats off, then turn back on, it starts again but it seems like the start/stop system is triggering the cooled seat fan to turn off for some reason.
Since the HVAC screen is still showing it's on, and it's an intermittent issue, I am thinking this is not usual operating procedure.
I've done some searches on the site here and don't see any threads discussing this issue.
Anyone experience something similar?
Edited by GTEyes
If the battery is low on charge, then load shedding takes placeandr electrical accessories are switched off. My advice is to turn off
the ASS feature as it will shorten the life of the turbos.
OOHH a Ford joke! If one does not switch off one's ASS his blower breaks! 🤣
I'm pretty sure this is normal behavior.  I have a 22 ST.  If I have the A/C on and the stop/start cuts off the engine at a light, I can hear the main blower fans slow down and the cooled seat noise disappear as well.  Otherwise, it would pull too much load off of the 12 volt battery.  This only lasts up to at most 30 seconds for me, as I will hear the engine come back on and all blowers go back up if I sit at the light very long.  I'm in Phoenix and it has been over 110 degrees recently, and in most cases the start/stop feature doesn't even engage in that heat because I'm sure there are programming parameters such as ambient temperature and what you have it set on in the car.  I don't think anything is wrong with yours.  I'm assuming all your fans come back on to what they were set for if you leave the controls alone and press the accelerator and the engine starts?
