Mike716 Posted September 18, 2020 Report Share Posted September 18, 2020 (edited) Hey guys I’m new to the forum and figured there is not better place to ask this question. I currently have a 2007 Ford Edge that has a horrible ticking noise and low oil pressure light at idle. The noise is constant and gets faster as rpm increases. I have to opportunity to get a free 3.7l with low miles out of a wrecked 2009 Lincoln MKS. The motors look identical, can I swap this with no ecu issues or programming or sensor problems? Edited September 18, 2020 by Mike716 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted September 20, 2020 Report Share Posted September 20, 2020 Might be a Ti-VCT, which would not be a dropin. You can look for Mazda CX9 3.7 engines of similar vintage which are VCT and would be dropin. Quote Link to comment Share on other sites More sharing options...
omar302 Posted September 20, 2020 Report Share Posted September 20, 2020 1 hour ago, WWWPerfA_ZN0W said: Might be a Ti-VCT, which would not be a dropin. You can look for Mazda CX9 3.7 engines of similar vintage which are VCT and would be dropin. I thought the Lincoln MKS only got the Ti-VCT in the 2013 refresh. Quote Link to comment Share on other sites More sharing options...
akirby Posted September 20, 2020 Report Share Posted September 20, 2020 11 hours ago, omar302 said: I thought the Lincoln MKS only got the Ti-VCT in the 2013 refresh. Correct Quote Link to comment Share on other sites More sharing options...
georgestash Posted July 8, 2023 Report Share Posted July 8, 2023 Did you ever go through with the swap? I have a 3.5 fusion with a failed water pump and a ruined bottom end. local pull a part has an 09 MKS im planning on getting Quote Link to comment Share on other sites More sharing options...
