ThugFordEdge3.5 Posted August 28, 2020 Report Share Posted August 28, 2020 I have been driving on the highway at different speeds with cruise control on at 70 MPH and then 80 MPH and also 90 MPH. I have the dash set to watch fuel efficiency and I get 6.8L/100km. That turns out to be 34.58 MPG. Now I'm not sure if the reason I'm getting such good milage would be because something is broken or not working correctly, but I don't think I've heard of anyone getting this before. Usual the milage is worse than the claim on the sticker. Has anyone gotten these numbers before? Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted August 28, 2020 Report Share Posted August 28, 2020 are you looking at instantaneous mpg perhaps, or right after fillup? this is typically when you get into the 3x's with a 3.5. A 2.0 typically easily manages 3x mpgs on highway drives. plus is this an imperial measurement? have to do a conversion to get the EPA rated mpg. Quote Link to comment Share on other sites More sharing options...
ThugFordEdge3.5 Posted August 28, 2020 Author Report Share Posted August 28, 2020 (edited) On 8/28/2020 at 10:10 PM, WWWPerfA_ZN0W said: are you looking at instantaneous mpg perhaps, or right after fillup? this is typically when you get into the 3x's with a 3.5. A 2.0 typically easily manages 3x mpgs on highway drives. plus is this an imperial measurement? have to do a conversion to get the EPA rated mpg. Expand I pick the option called fuel economy. Not trip 1 or trip 2. It's looks like this after driving for 10 minutes on cruise control at 80 MPH. It's says fuel economy on top and then says average 6.8l/100km and I also press OK and hold down to reset it first. I'll add a screenshot of the example I found online just now. When I do the conversion to U.S miles per gallon it gives me 34.59 U.S miles per gallon. I do have over 3/4 of tank full of gas and lately I been using premium 91 octane, and I also use Lucas upper cylinder lubricant or marvel mystery oil in every gas fill up. I use 0W-20 Amsoil Signature Series with liquid moly Cera tec friction modifier along with K&N oil filter and Wix engine air filter.. First time using Cera tec friction modifier was in my last oil change 3 months ago. I still can't see these products making this much of a difference on gas mileage, but Maybe it's the combination of everything I'm using. I hope it's because everything is working great and not something that's about to let go lol. BTW, I have the basic duratec 3.5L V6 no turbo Edited August 28, 2020 by ThugFordEdge3.5 1 Quote Link to comment Share on other sites More sharing options...
Perblue Posted August 29, 2020 Report Share Posted August 29, 2020 I got that once when I had my 3.5l, with the wind pushing. Turned around for return trip same day she was doing 24. On a 10 hour drive I averaged 28. I would be amazed if it maintained that over a few hours. Most also don't reset it on the highway, they include getting up to speed and such resulting in much lower mpg. I'd get alot better than 30-32 out of my ST if I did like you. Even the ratings are calculated over an entire tank, not if you were already going XX speed. 1 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted August 29, 2020 Report Share Posted August 29, 2020 Fuel Economy • Distance to Empty - Shows the approximate distance your vehicle can travel before running out of fuel. • Inst Fuel Economy - Shows a visual graph of your instantaneous fuel economy along with your Avg MPG since the function was last reset. • Long Term Fuel Economy - Shows your long term fuel economy. • Average MPG — Shows the average fuel economy for a given trip. • All Values — Shows all fuel economy values (DTE, Inst Fuel Econ, Avg Fuel). • Auto StartStop - Available Auto Start-Stop messaging will provide details about what is happening with your system. See Information Messages (page 112). Note: You can reset your average fuel economy by pressing and holding the OK button on the left hand steering wheel controls. Quote Link to comment Share on other sites More sharing options...
ThugFordEdge3.5 Posted August 29, 2020 Author Report Share Posted August 29, 2020 On 8/29/2020 at 1:24 AM, Perblue said: I got that once when I had my 3.5l, with the wind pushing. Turned around for return trip same day she was doing 24. On a 10 hour drive I averaged 28. I would be amazed if it maintained that over a few hours. Most also don't reset it on the highway, they include getting up to speed and such resulting in much lower mpg. I'd get alot better than 30-32 out of my ST if I did like you. Even the ratings are calculated over an entire tank, not if you were already going XX speed. Expand It could very well be the wind helping out. I can't remember if I had watched the gauge both ways going and coming. I'll have to test that next time. Quote Link to comment Share on other sites More sharing options...
ThugFordEdge3.5 Posted August 29, 2020 Author Report Share Posted August 29, 2020 On 8/29/2020 at 11:48 AM, WWWPerfA_ZN0W said: Fuel Economy • Distance to Empty - Shows the approximate distance your vehicle can travel before running out of fuel. • Inst Fuel Economy - Shows a visual graph of your instantaneous fuel economy along with your Avg MPG since the function was last reset. • Long Term Fuel Economy - Shows your long term fuel economy. • Average MPG — Shows the average fuel economy for a given trip. • All Values — Shows all fuel economy values (DTE, Inst Fuel Econ, Avg Fuel). • Auto StartStop - Available Auto Start-Stop messaging will provide details about what is happening with your system. See Information Messages (page 112). Note: You can reset your average fuel economy by pressing and holding the OK button on the left hand steering wheel controls. Expand It's was the inst fuel economy that I had on. Also pressed ok button for reset first. I'm just changing my rear differential oil today. Draining as I type this. 38,543 km and is it ever dark silver color. Looks like 500 ml total left in there. Supposed to be 1.1 liters lol. I'll say there is 600 ml since I can't get it all. I wonder if I'll get even better gas mileage after this. Quote Link to comment Share on other sites More sharing options...
Tightanium Posted August 29, 2020 Report Share Posted August 29, 2020 On 8/28/2020 at 10:52 PM, ThugFordEdge3.5 said: I pick the option called fuel economy. Not trip 1 or trip 2. It's looks like this after driving for 10 minutes on cruise control at 80 MPH. It's says fuel economy on top and then says average 6.8l/100km and I also press OK and hold down to reset it first. I'll add a screenshot of the example I found online just now. When I do the conversion to U.S miles per gallon it gives me 34.59 U.S miles per gallon. I do have over 3/4 of tank full of gas and lately I been using premium 91 octane, and I also use Lucas upper cylinder lubricant or marvel mystery oil in every gas fill up. I use 0W-20 Amsoil Signature Series with liquid moly Cera tec friction modifier along with K&N oil filter and Wix engine air filter.. First time using Cera tec friction modifier was in my last oil change 3 months ago. I still can't see these products making this much of a difference on gas mileage, but Maybe it's the combination of everything I'm using. I hope it's because everything is working great and not something that's about to let go lol. BTW, I have the basic duratec 3.5L V6 no turbo Expand Isn’t the first little line left of 15 your real average mpg? I don’t really look at that gauge for mpg. I try using trip 2 as ave mpg. Sometimes I never reset 2 and after 4 or 5k Miles I’m at 19 mpg. Quote Link to comment Share on other sites More sharing options...
Tightanium Posted August 29, 2020 Report Share Posted August 29, 2020 This is the gauge you should use. Almost 100 hours of driving there. Quote Link to comment Share on other sites More sharing options...
ThugFordEdge3.5 Posted August 29, 2020 Author Report Share Posted August 29, 2020 (edited) On 8/29/2020 at 10:12 PM, Tightanium said: Isn’t the first little line left of 15 your real average mpg? I don’t really look at that gauge for mpg. I try using trip 2 as ave mpg. Sometimes I never reset 2 and after 4 or 5k Miles I’m at 19 mpg. Expand On 8/29/2020 at 10:16 PM, Tightanium said: This is the gauge you should use. Almost 100 hours of driving there. Expand I do have the trip 1 and 2 on. It's been calculating for couple months. Mostly in town driving with about 30 minutes of highway and it's at 14.2l/100km conversion in MPG is 16.56 MPG, and the newer trip 1 that's about 3 weeks old is showing I think 13.8l100km but I'm guessing it's gonna slowly get up to trip 2 at 14.2l/100km. I get horrible gas mileage in town. Is it possible one or 2 of my injectors are plugged or dirty causing less gas to be injected when going faster? Maybe that's why I'm getting such good results when going higher steady speeds. Or maybe cruise control activates the AWD less when it's maintaining a specific speed instead of having constant different acceleration inputs that usually activate the AWD. BTW, I don't think I have MPG calculation option on my 2017 Edge Titanium. It has pretty much all other conversions. Wonder if that's because I got mine in Canada? I'll have to check to make sure. If I have the MPG I'll certainly use that from now on. Edited August 29, 2020 by ThugFordEdge3.5 Quote Link to comment Share on other sites More sharing options...
Perblue Posted August 29, 2020 Report Share Posted August 29, 2020 On 8/29/2020 at 10:51 PM, ThugFordEdge3.5 said: I do have the trip 1 and 2 on. It's been calculating for couple months. Mostly in town driving with about 30 minutes of highway and it's at 14.2l/100km conversion in MPG is 16.56 MPG, and the newer trip 1 that's about 3 weeks old is showing I think 13.8l100km but I'm guessing it's gonna slowly get up to trip 2 at 14.2l/100km. I get horrible gas mileage in town. Is it possible one or 2 of my injectors are plugged or dirty causing less gas to be injected when going faster? Maybe that's why I'm getting such good results when going higher steady speeds. Expand Doubt it you would have problems showing up. I got 14-16mpg city driving lots of stop and go. On 8/29/2020 at 10:51 PM, ThugFordEdge3.5 said: Or maybe cruise control activates the AWD less when it's maintaining a specific speed instead of having constant different acceleration inputs that usually activate the AWD. Expand This does happen on all edges. On 8/29/2020 at 10:51 PM, ThugFordEdge3.5 said: BTW, I don't think I have MPG calculation option on my 2017 Edge Titanium. It has pretty much all other conversions. Wonder if that's because I got mine in Canada? I'll have to check to make sure. If I have the MPG I'll certainly use that from now on. Expand Go into your settings on the left screen and change Units from L/100km to mpg. It will switch it all to US mpg. You still have to calculate canadian mpg. Which by the way I did achieve sometimes with my 3.5 if you are calculating canadian mpg, but in US mpg like I said above I did once with a tail wind. Quote Link to comment Share on other sites More sharing options...
ThugFordEdge3.5 Posted August 30, 2020 Author Report Share Posted August 30, 2020 On 8/29/2020 at 11:24 PM, Perblue said: Doubt it you would have problems showing up. I got 14-16mpg city driving lots of stop and go. This does happen on all edges. Go into your settings on the left screen and change Units from L/100km to mpg. It will switch it all to US mpg. You still have to calculate canadian mpg. Which by the way I did achieve sometimes with my 3.5 if you are calculating canadian mpg, but in US mpg like I said above I did once with a tail wind. Expand Ok, I just came back from driving around the city, and while driving I found the option your speaking of. I switched to MPG. I also hit ok to reset, and last 10 minutes of driving I got an average of 22 MPG but it was bouncing from 21.4 to 23 when I looked a few times. When I got home I checked before turning off and was at 22 MPG. Seems pretty good but it's really depending on how many red lights I hit. It's most likely gonna get worse as I sit in drive thru for coffee all the time lol. Quote Link to comment Share on other sites More sharing options...
Perblue Posted August 30, 2020 Report Share Posted August 30, 2020 On 8/30/2020 at 1:47 AM, ThugFordEdge3.5 said: Ok, I just came back from driving around the city, and while driving I found the option your speaking of. I switched to MPG. I also hit ok to reset, and last 10 minutes of driving I got an average of 22 MPG but it was bouncing from 21.4 to 23 when I looked a few times. When I got home I checked before turning off and was at 22 MPG. Seems pretty good but it's really depending on how many red lights I hit. It's most likely gonna get worse as I sit in drive thru for coffee all the time lol. Expand Yep, drive thrus, idling and lights/stop signs will drop that fast. That's why I only averaged 14 city with the 3.5, not many cruising roads here. Quote Link to comment Share on other sites More sharing options...
ThugFordEdge3.5 Posted August 31, 2020 Author Report Share Posted August 31, 2020 (edited) On 8/30/2020 at 3:15 AM, Perblue said: Yep, drive thrus, idling and lights/stop signs will drop that fast. That's why I only averaged 14 city with the 3.5, not many cruising roads here. Expand Well, I figured out why I'm getting amazing gas mileage. I went in to grab coffee instead of drive thru, and I could hear what sounds like a full pressurized propane tank wide open leaking air just below the rear of my Edge. Basically the gas tank area. I'm assuming my fuel pump or fuel line is losing pressure. There isn't any gas leaking, just pure air sound coming out from around there. So I think that rules out fuel line leaking air. it might be the fuel tank ventilation system that's plugged up. I'll have to check it all out. I did notice that when I press the gas pedal I don't get the same torque as I used to. Slightly less power. That 35 MPG was unfortunately to good to be true lol Edited August 31, 2020 by ThugFordEdge3.5 1 2 Quote Link to comment Share on other sites More sharing options...
Perblue Posted September 1, 2020 Report Share Posted September 1, 2020 If that's what is, it's not often you gain mileage with a problem. Will be interesting to hear what it is and if it dips down. Unless you want to leave it to keep the mileage haha, but I'm sure it would cause other issues down the road. 1 Quote Link to comment Share on other sites More sharing options...
ThugFordEdge3.5 Posted September 2, 2020 Author Report Share Posted September 2, 2020 On 9/1/2020 at 3:55 AM, Perblue said: If that's what is, it's not often you gain mileage with a problem. Will be interesting to hear what it is and if it dips down. Unless you want to leave it to keep the mileage haha, but I'm sure it would cause other issues down the road. Expand I'll know what it is for sure in a few days. I just ordered the Launch X431 V+ Professional diagnostic scan tool. The first thing I'll test will be the EVAP system, then fuel pump. The air hissing noise starts off low when the SUV starts for the first time of the day. If it's running for about 20 minutes or more it gets much louder. I wonder if that might be the EGR valve causing a build up of pressure from the suction. Quote Link to comment Share on other sites More sharing options...
Perblue Posted September 2, 2020 Report Share Posted September 2, 2020 On 9/2/2020 at 1:38 AM, ThugFordEdge3.5 said: I'll know what it is for sure in a few days. I just ordered the Launch X431 V+ Professional diagnostic scan tool. The first thing I'll test will be the EVAP system, then fuel pump. The air hissing noise starts off low when the SUV starts for the first time of the day. If it's running for about 20 minutes or more it gets much louder. I wonder if that might be the EGR valve causing a build up of pressure from the suction. Expand The egr valve is no where near the tank. Quote Link to comment Share on other sites More sharing options...
ThugFordEdge3.5 Posted October 7, 2020 Author Report Share Posted October 7, 2020 On 9/2/2020 at 2:35 AM, Perblue said: The egr valve is no where near the tank. Expand Very true. I think I meant the EVAP canister in the rear. Quote Link to comment Share on other sites More sharing options...
Perblue Posted October 7, 2020 Report Share Posted October 7, 2020 On 10/7/2020 at 1:56 PM, ThugFordEdge3.5 said: Very true. I think I meant the EVAP canister in the rear. Expand That makes sense! ? Quote Link to comment Share on other sites More sharing options...
