Svaresi Posted August 21, 2020 Report Share Posted August 21, 2020 (edited) Driver door switch BAD what to do should be a recall on driver door issues. It's across multiple years and models. My 2013 ford edge has this issue and I'm now waiting on jump start due to it draining battery Edited August 21, 2020 by 1004ron Duplicate posts and threads merged Quote Link to comment Share on other sites More sharing options...
Perblue Posted August 21, 2020 Report Share Posted August 21, 2020 ? The driver door latch is mechanical, I'm not sure how it could drain the battery. I never had a problem with my 2013 or 2019. 1 Quote Link to comment Share on other sites More sharing options...
Perblue Posted August 21, 2020 Report Share Posted August 21, 2020 21 minutes ago, Svaresi said: should be a recall ondriverdoor issues. It's across multiple years and models. My 2013 ford edge has this issue and I'm now waiting on jump start due to it draining battery Shouldn't make new topics saying the same thing you made in another topic. your post only makes sense here where it has context. At the same time you must have a weak battery or drive short distances. My 13 always turned off all the lights even with the door left open for extended periods and never had an issue starting afterwards . 1 Quote Link to comment Share on other sites More sharing options...
1004ron Posted August 21, 2020 Report Share Posted August 21, 2020 1 hour ago, Svaresi said: should be a recall on driverdoor issues. It's across multiple years and models. My 2013 ford edge has this issue and I'm now waiting on jump start due to it draining battery Do you have a link to this issue that you say is reported on multiple years and models - please post it here. What's actually happening with yours that leads you to believe that its your door latch causing the battery to drain? Quote Link to comment Share on other sites More sharing options...
1004ron Posted August 21, 2020 Report Share Posted August 21, 2020 1 hour ago, Perblue said: Shouldn't make new topics saying the same thing you made in another topic. your post only makes sense here where it has context. At the same time you must have a weak battery or drive short distances. My 13 always turned off all the lights even with the door left open for extended periods and never had an issue starting afterwards . Thanks - merged. Quote Link to comment Share on other sites More sharing options...
bpainter03 Posted October 24, 2021 Report Share Posted October 24, 2021 Hello! Just purchased a 2014 edge yesterday and noticed a couple of times the ajar warning with the door shut. I did a VIN recall search and was not able to find any applicable to my vehicle. If this is not a safety recall is it just a notice letter from Ford? What actions were needed by owners? Could anyone forward a PII redacted copy of the letter to me? Thanks! Brad Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted October 29, 2021 Report Share Posted October 29, 2021 This is the recall you're probably thinking of https://www.mcdavidford.com/door-latch-recall.htm Theres no recall on the switch failure that I'm aware of. Youtube has videos showing how to replace it yourself. Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted October 29, 2021 Report Share Posted October 29, 2021 https://drive.google.com/file/d/1IsCOd6ym6nm-rwAd5fhg0VG3DRsz92wi/view?usp=sharing Quote Link to comment Share on other sites More sharing options...
