Latrece370 Posted April 27, 2016 Report Share Posted April 27, 2016 Hello, So I'm running into this problem where no matter how many times I slam my door, it still says "Driver Door Ajar". And I know I'm getting my door shut, but the car thinks I'm not. I'm at my wits end with it. It use to go away after slamming it 8-12 times, now it wont go away. Its draining my battery and my doors wont lock because it thinks the driver door is still open. And since I DIDN'T by it from Ford, I bought it off a used lot at Lithia BMW Mini here in Anchorage, Ak, I have to call them first (I already called my local Ford Store)... That was 2 days ago (as of today 4/27/16). Im hoping to get somewhere later on lunch, but I'm not holding my breath. Any help you could offer would be greatly appreciated! Quote Link to comment Share on other sites More sharing options...
wlepse Posted April 27, 2016 Report Share Posted April 27, 2016 Unfortunately this is a common problem. I have had my latch replaced before and it came back. I think Ford just has a faulty design and unfortunately they won't do anything for you unless you are under warranty. Repair cost is fairly high, around 500 so some here have come up with alternate fixes with a switch in parallel. Doo a search on reed switch and you should find a video showing the set up. 1 Quote Link to comment Share on other sites More sharing options...
omar302 Posted April 28, 2016 Report Share Posted April 28, 2016 You have a 2013, even if it was purchased used from a non-Ford dealer, it might still be under warranty if it was originally purchased mid/late 2013 & mileage is under 36K miles. 1 Quote Link to comment Share on other sites More sharing options...
reddyroc Posted April 28, 2016 Report Share Posted April 28, 2016 I noticed my driver's door is starting to do this on my 2013. I was hoping it was due to the recent melt of our snow and ice buildup but its still sticking. I can open and shut my door and it corrects itself but how long will that last for :/ Keep us updated Quote Link to comment Share on other sites More sharing options...
pilotdog68 Posted April 28, 2016 Report Share Posted April 28, 2016 Just FYI there are a few threads here that give different ways to resolve the issue (other than taking it to the dealer). If you search just "door ajar" you'll find the threads. I'd post a link but I'm on my mobile Quote Link to comment Share on other sites More sharing options...
wlepse Posted April 28, 2016 Report Share Posted April 28, 2016 All of the "fixes" are temporary at best. But truth is so is replacement of the lock assembly. It will fail again because it is a crappy design. When I get time and get the parts assembled I will be doing the other switch in parallel to fix this for good. 1 Quote Link to comment Share on other sites More sharing options...
omar302 Posted April 29, 2016 Report Share Posted April 29, 2016 All of the "fixes" are temporary at best. But truth is so is replacement of the lock assembly. It will fail again because it is a crappy design. When I get time and get the parts assembled I will be doing the other switch in parallel to fix this for good. Though I agree it is a crappy design, many don't face the problem. Also Ford updated the switch (Part number ending with B replaced A), so replacements should be better. Also, as per the latest TSB, the fix has to do with some electrical/heating fix. Also now there are alternative aftermarket parts. http://www.amazon.com/APDTY-Integrated-Driver-Side-7T4Z7821813C-8T4Z7821813A/dp/B00QB4EWQC/ref=sr_1_5?ie=UTF8&qid=1461901118&sr=8-5&keywords=ford+edge+door+latch http://www.amazon.com/Dorman-937-628-Door-Lock-Actuator/dp/B00HRSSSCA/ref=pd_sim_sbs_263_1?ie=UTF8&dpID=4132Xo8I1gL&dpSrc=sims&preST=_AC_UL160_SR160%2C160_&refRID=04PQ6Q6G39ZDBV2V7VE3 1 Quote Link to comment Share on other sites More sharing options...
wlepse Posted April 29, 2016 Report Share Posted April 29, 2016 (edited) I will check my invoice from the last time it was replaced but I recall the dealer saying it was an updated part, but he could have been BSing me. So if I did get the updated one, so much for it being better. By the way thanks for the links to aftermarket parts. For me though I will stick with the reed switch work around which will cost almost nothing and be significantly easier to do. Edited April 29, 2016 by wlepse Quote Link to comment Share on other sites More sharing options...
Msmarshall7 Posted May 3, 2016 Report Share Posted May 3, 2016 This is happening to my vehicle as well. I own a Ford Edge with 20,000 miles when I purchased. This is a headache combined with my screen blacking out. Starting to hate I left Toyota! Quote Link to comment Share on other sites More sharing options...
KY13EdgeLtd Posted September 7, 2016 Report Share Posted September 7, 2016 Im also having the door ajar problem with my 2013 Edge Ltd. I feel like its more of a sensor problem because today I got in & shut the door & the door ajar light stayed on. Stopped at a stop sign then started going again & the door ajar light went off & my doors locked. Without me doing anything. Ford really needs to address this issue with a recall. This is my 1st Ford & Im thinking this will be my last! Quote Link to comment Share on other sites More sharing options...
KayDorman Posted September 14, 2016 Report Share Posted September 14, 2016 My 2012 Edge just started doing the same. No matter how hard or as many times the driver door is closed, the door ajar sensor lights up and there are warning chimes too. The most troubling is the in car lights stay on and the doors won't lock! After reading about the recall and most recent addition of vehicles to the recall, I believe it is the same issue I have. I called dealer service department for an appointment and they told me my vehicle is not part of the recall. I am going to have a fight on my hands but I will not be paying one penny to fix this problem! Please update me to any of your progress with your cars. If there are enough Edge owners that demand help then maybe recall will be expanded. 1 Quote Link to comment Share on other sites More sharing options...
akirby Posted September 14, 2016 Report Share Posted September 14, 2016 After reading about the recall and most recent addition of vehicles to the recall, I believe it is the same issue I have. I called dealer service department for an appointment and they told me my vehicle is not part of the recall. I am going to have a fight on my hands but I will not be paying one penny to fix this problem! Please update me to any of your progress with your cars. If there are enough Edge owners that demand help then maybe recall will be expanded. There is NO recall on Edge door latches for this sensor problem. There is a recall on Fusion and other vehicles (not Edge) for door latches but that's due to the latch actually breaking and the door coming open. That happened to my Fusion last week and I got all of the latches replaced per the recall. They're not going to include the sensor failures in the recall. Good luck to you if you want to fight it but I wouldn't hold my breath. When you pay to get it fixed (which I can almost guarantee will happen) keep the receipt in case Ford does extend the recall to the Edge down the road. Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted September 15, 2016 Report Share Posted September 15, 2016 (edited) There are several attempts for a repair on this problem, here's a good example on how one fella did a quick, two minute fix. (below). It seems to be related to a plastic "arm" that triggers the switch getting gunked up a sticking in the up position. There are several videos on YouTube, check this one out and see if will help those of you having this problem. Edited September 15, 2016 by enigma-2 Quote Link to comment Share on other sites More sharing options...
KayDorman Posted September 15, 2016 Report Share Posted September 15, 2016 I filed a complaint with the National Highway and Traffic Safety Administration.If there are enough complaints then their engineers will look at the problem. Curiously,on the the NHTSA website there are 2 communications between Ford manufacturers that say this is a problem and how it should be fixed. When doors can't lock,it is a safety issue. Ford needs to take responsibility. Quote Link to comment Share on other sites More sharing options...
akirby Posted September 15, 2016 Report Share Posted September 15, 2016 If you think it's a safety issue you wouldn't be driving around with it not fixed. You'd pay immediately to fix it, then worry about whether you get reimbursed. I agree it should be covered by an extended warranty, but saying it should be recalled is a stretch. Door latches that break and let the door open at speed is a serious safety issue. Quote Link to comment Share on other sites More sharing options...
KayDorman Posted September 16, 2016 Report Share Posted September 16, 2016 Easy for you to say "pay immediately" akirby! Doors that don't lock is a safety issue. Ford knows it is a problem with many Edge vehicles.For those two reasons,it is not a stretch for it to be a recall! Quote Link to comment Share on other sites More sharing options...
akirby Posted September 16, 2016 Report Share Posted September 16, 2016 If you truly think it's a safety issue you should either fix it or stop driving it and convince the NHTSA that it deserves a recall. I suspect what you really want so for Ford to pay for the repair out of warranty and I don't blame you for wanting that. But short of a NHTSA mandate I don't think it will happen. Quote Link to comment Share on other sites More sharing options...
CinnamonEdge Posted October 4, 2016 Report Share Posted October 4, 2016 Well you might get your wish. NHTSA is investigating the issue. Mine wasn't letting me lock the doors or use my auto start. I consider no locks a serious problem. Ford did fix it under the original warranty. I hope that the extended warranty would cover it also. Quote Link to comment Share on other sites More sharing options...
Rollingrock Posted October 6, 2016 Report Share Posted October 6, 2016 I saw on the news that Ford is about to recall the Ford Edge for the door ajar issue. Hopefully they do this recall soon. Quote Link to comment Share on other sites More sharing options...
FixerUpper Posted October 2, 2018 Report Share Posted October 2, 2018 2013 Ford Edge, Driver side door was the culprit. Tried the lubrication method which didn't work. But I fixed it in 20 minutes. Remove the bottom door paneling to expose the wiring at the front. Use a tester that's earthed. You'll see a medium sized green wire. Earth that out and look to see if the Door Ajar warning goes off. If so, just run a wire from there to earth it out. Easy. However, remember that this now means you have no warning when a door is ajar, so that's a liability you have to take on yourself. 1 Quote Link to comment Share on other sites More sharing options...
punman Posted February 18, 2020 Report Share Posted February 18, 2020 I received a letter from Ford yesterday (February 17, 2020) saying they will replace the door latch on my 2013 Ford Edge SEL (FWD). SO there you go. After all these years, Ford decides to do the right thing and correct this issue. Quote Link to comment Share on other sites More sharing options...
akirby Posted February 18, 2020 Report Share Posted February 18, 2020 2 hours ago, punman said: I received a letter from Ford yesterday (February 17, 2020) saying they will replace the door latch on my 2013 Ford Edge SEL (FWD). SO there you go. After all these years, Ford decides to do the right thing and correct this issue. Does it specifically state the door ajar warning is covered? I thought it was the same as Fusion - the door latch itself fails and you can't close the door, which is a pretty rare occurrence. Not the door ajar sensor issue. Quote Link to comment Share on other sites More sharing options...
redcox30 Posted March 9, 2020 Report Share Posted March 9, 2020 (edited) Does your letter have contact info for Ford on it so we can get ours fixed too? Was it from corporate, or your local dealer? Edited March 9, 2020 by redcox30 Quote Link to comment Share on other sites More sharing options...
akirby Posted March 9, 2020 Report Share Posted March 9, 2020 3 hours ago, redcox30 said: Does your letter have contact info for Ford on it so we can get ours fixed too? Was it from corporate, or your local dealer? Just call your dealer. Quote Link to comment Share on other sites More sharing options...
akirby Posted March 9, 2020 Report Share Posted March 9, 2020 On 2/18/2020 at 12:41 PM, akirby said: Does it specifically state the door ajar warning is covered? I thought it was the same as Fusion - the door latch itself fails and you can't close the door, which is a pretty rare occurrence. Not the door ajar sensor issue. I was wrong - this is for the door ajar issue. Quote Link to comment Share on other sites More sharing options...
