Sirius module Vin specific?
I believe that the SDARS module needs to be programmed during installation by the dealer. Ford dealers offer a module exchange for audio items. I would call the parts deparment at your local dealer and ask about it.
There is one (possible) "test" you could try first. Gain access to the module and give it a sharp rap. (Usual failure is a failed solder joint and sometimes a rap on the outside of the case will fix it. (Can't hurt a failed unit).
