Scott Q Posted August 11, 2020 Report Share Posted August 11, 2020 Is there a PVC valve in a 2017 2.0 echoboost? Quote Link to comment Share on other sites More sharing options...
1004ron Posted August 11, 2020 Report Share Posted August 11, 2020 1 hour ago, Scott Q said: Is there a PVC valve in a 2017 2.0 echoboost? Welcome. The 2.0 ecoboost does have a Positive Crankcase Ventilation (PCV) valve. Please consider adding your location and Model/Year to your profile signature - https://www.fordedgeforum.com/settings/signature/ 1 Quote Link to comment Share on other sites More sharing options...
Scott Q Posted August 11, 2020 Author Report Share Posted August 11, 2020 Do you know where it is located? Quote Link to comment Share on other sites More sharing options...
dajo2012 Posted August 11, 2020 Report Share Posted August 11, 2020 Most pcv vales are located on the valve cover. Quote Link to comment Share on other sites More sharing options...
Cwl111286 Posted August 13, 2020 Report Share Posted August 13, 2020 Not sure if they changed it but the pcv valve or oil separator is under the air intake on the front of our 2012 2.0 Ecoboost. Quote Link to comment Share on other sites More sharing options...
Scott Q Posted August 14, 2020 Author Report Share Posted August 14, 2020 Thanks everyone for all the great feed back. Ford confirmed everything posted, however it was the sensor for the valve that was bad. Ford covered the part and labor. Quote Link to comment Share on other sites More sharing options...
Armorer1984 Posted October 11, 2020 Report Share Posted October 11, 2020 I just put my hands on it this afternoon. It's behind the intake manifold. If you unclip a couple vacuum lines and other tidbits, remove the 5 bolts holding the intake manifold, you can get to it. It's ugly, but it can be done. Quote Link to comment Share on other sites More sharing options...
