duck67 Posted August 3, 2020 Report Share Posted August 3, 2020 I was traveling last weekend and al of a sudden the ABS (amber) light and the TRAC off symbol illuminated. I lost cruise control as well. When I shut down and restarted I got warnings for the Traction control, collision avoidance and adaptive cruise control inop. The brakes seemed a little different but still worked. The next day, I started the car and after the light test phase I had no lights. After driving I got the ABS etc on again. Anyone have any thoughts on this? Could brake booster issue be the culprit? Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted August 4, 2020 Report Share Posted August 4, 2020 (edited) I would run a CCA test on the vehicle battery. An old battery, nearing its end will cause failures similar to this. (A straight voltage test is insufficient. It must be a CCA test to diagnose a modern battery properly). This is what I use (there is a less expensive version that just measures the battery, this version also checks the charging system): https://www.amazon.com/dp/B0015PI7A4/ref=cm_sw_r_cp_apa_i_zenkFb8JP6YS4 Edited August 4, 2020 by enigma-2 Add link Quote Link to comment Share on other sites More sharing options...
Perblue Posted August 4, 2020 Report Share Posted August 4, 2020 3 hours ago, enigma-2 said: I would run a CCA test on the vehicle battery. An old battery, nearing its end will cause failures similar to this. (A straight voltage test is insufficient. It must be a CCA test to diagnose a modern battery properly). This is what I use (there is a less expensive version that just measures the battery, this version also checks the charging system): https://www.amazon.com/dp/B0015PI7A4/ref=cm_sw_r_cp_apa_i_zenkFb8JP6YS4 But the one listed with it is cheaper and the better tester with system test going by specs and the hierarchy chart down lower. https://www.amazon.com/dp/B00IZFNJ6Y/ref=cm_sw_r_cp_apa_i_zenkFb8JP6YS4?th=1 Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted August 6, 2020 Report Share Posted August 6, 2020 (edited) The BA-7 costs more because it will do all the battery tests PLUS it tests the alternator, starting and charging system. Edited August 6, 2020 by enigma-2 Quote Link to comment Share on other sites More sharing options...
