2020 EDGE SEL AWD
gurunutkins
First up should be to replace the single horn with the 2018 dual horns. Search horn on this site. I left the OEM bracket is place and just swapped the single horn for the 2018 High/Low horns,  others replace the bracket but have to remove the up horn to get at at the bracket mounting bolt. Bracket is the same. Took 15 minutes max. 10MM 1/4 drive socket, with a short extension for the two high light bolts so I could spin the handle around. One plastic keeper to remove next to the fender side head light bolt.  Now our 2020 ST has a proper horn. BTW, I am a little North of mid 70's and love driving the ST. Zoom zoom. A modern 4500 pound SUV with 335HP that is faster then the 3300 pound 295HP 1967 SS 350 Camaro I had back then. Chris
Edited by Snoking
