Van G Posted July 9, 2020 Report Share Posted July 9, 2020 Cigarette Lighter - Power Point below the radio/ac cluster - is dead. I checked fuses under the hood and all the power point's look fine: F17, F64, F65, F66 I even switched out F65 and F17 but no luck. What should I check next? Quote Link to comment Share on other sites More sharing options...
akirby Posted July 9, 2020 Report Share Posted July 9, 2020 Make sure there isn’t a coin lodged in it. Might also be a different fuse. Quote Link to comment Share on other sites More sharing options...
Van G Posted July 9, 2020 Author Report Share Posted July 9, 2020 From what I can find online those are the 4 Power Point fuses - F17 being for the one I'm looking at. Just checked the outlet - clear and looks fine. Quote Link to comment Share on other sites More sharing options...
akirby Posted July 9, 2020 Report Share Posted July 9, 2020 Yep that looks correct. Have you tested it with a voltmeter or a 2nd device? Maybe your plug is bad. Quote Link to comment Share on other sites More sharing options...
