ALLEN007 Posted July 7, 2020 Report Share Posted July 7, 2020 My 2012 back-up camera was working intermittently. I decided to upgrade from SYNC 2 to SYNC 3. After doing that still no change with the camera. But after a couple weeks it finally quit working all together. I replaced the camera yesterday and the camera works fine now but has no guide lines. I have seen a bunch of others with this same issue. Did anyone figure this out short of taking it to the dealer? Quote Link to comment Share on other sites More sharing options...
Gadgetjq Posted July 7, 2020 Report Share Posted July 7, 2020 Is your replacement a genuine Motorcraft part for your year or is it one of those aftermarket (eBay/Amazon etc) cameras? If it's the latter you just have to cut either the green or white wire sticking out of the camera cable. If it's OEM there's probably a sync process someone else can help with. Quote Link to comment Share on other sites More sharing options...
DaMiFo Posted July 7, 2020 Report Share Posted July 7, 2020 You will need to initialize the camera so it works with the car's other systems. Either a dealer can do this, or you can do it on your own if you are familiar with how to use FORScan. Quote Link to comment Share on other sites More sharing options...
ALLEN007 Posted July 8, 2020 Author Report Share Posted July 8, 2020 It's an OEM camera. Thanks for the response. I'll check into the Forscan. Quote Link to comment Share on other sites More sharing options...
