dashboard oil lamp switch
Ochaiks
Hell forum,
Does anyone have an experience of dashboard oil lamp light coming on after a repair and staying on. Oil level is ok.
How does one eliminate a false oil lamp light on the dashboard? Where can I locate the oil switch or sensor in a Ford Edge 2010?
Thanks for any help.
Thanxalot for the video clip. I double checked the connections in the engine bay and found a loose connector close to the oil filter. I believe this came off the oil switch and is probably the cause of the oil engine pressure lamp staying on.
Once more, thanks for the help
