Ochaiks Posted July 6, 2020 Report Share Posted July 6, 2020 Hell forum, Does anyone have an experience of dashboard oil lamp light coming on after a repair and staying on. Oil level is ok. How does one eliminate a false oil lamp light on the dashboard? Where can I locate the oil switch or sensor in a Ford Edge 2010? Thanks for any help. Quote Link to comment Share on other sites More sharing options...
Gadgetjq Posted July 6, 2020 Report Share Posted July 6, 2020 Your best bet is to watch this MacT video: Quote Link to comment Share on other sites More sharing options...
Ochaiks Posted July 6, 2020 Author Report Share Posted July 6, 2020 Thanxalot for the video clip. I double checked the connections in the engine bay and found a loose connector close to the oil filter. I believe this came off the oil switch and is probably the cause of the oil engine pressure lamp staying on. Once more, thanks for the help Quote Link to comment Share on other sites More sharing options...
PaulSchott Posted July 14, 2020 Report Share Posted July 14, 2020 If you have the 3.5 the switch is on the front of the engine between the radiator and engine on the passenger side. Quote Link to comment Share on other sites More sharing options...
