Palladini Posted July 6, 2020 Report Share Posted July 6, 2020 We own a 2015 for Edge SEL 4WD and I have a Red Tec 12a Bottle and it will not fit on AC recharge port under hood on the AC line. https://youtu.be/2mtUzI5TMnA I mad a video showing what I have. This device has worked on any car I had, have they changed the fitting on these newer cars. Does red tec have the required fitting to allow me to do this refill? Quote Link to comment Share on other sites More sharing options...
Gadgetjq Posted July 6, 2020 Report Share Posted July 6, 2020 The different size connectors have prevented you from making a huge mistake. You're trying to put R12 into an R134 system. The low pressure side connection for R134 will be a 13mm fitting, for R12 it's 7/16". Toss the R12 (or better, take it to an AC repair shop so it can be saved in a special tank) and get an R134 kit for recharging. BTW there should be a sticker near the hood latch telling you what refrigerant is in the system. Quote Link to comment Share on other sites More sharing options...
Palladini Posted July 6, 2020 Author Report Share Posted July 6, 2020 OK Gadgetjq Going to this site https://www.canadiantire.ca/en/search-results.html?x1=brand;q1=Red+Tek could you tell me what I would need to get? Quote Link to comment Share on other sites More sharing options...
Gadgetjq Posted July 6, 2020 Report Share Posted July 6, 2020 I don't see an R134A recharge kit anyplace on the site you referenced. Try Amazon where there are many options. Here are a couple of examples (from the U.S. site, not CA) Small containers of R134 https://amzn.to/2DbYYy9 Depending how low your system is you might only need a single can or ???? This is the hose and gauge (that you'll be able to reuse for many years) https://amzn.to/2Z3Vian Another option is one that includes the bottle of refrigerant already attached to a hose and gauge. I don't know if you can reuse any part of it though. 1 Quote Link to comment Share on other sites More sharing options...
handfiler Posted July 6, 2020 Report Share Posted July 6, 2020 6 hours ago, Gadgetjq said: The different size connectors have prevented you from making a huge mistake. You're trying to put R12 into an R134 system. The low pressure side connection for R134 will be a 13mm fitting, for R12 it's 7/16". Toss the R12 (or better, take it to an AC repair shop so it can be saved in a special tank) and get an R134 kit for recharging. BTW there should be a sticker near the hood latch telling you what refrigerant is in the system. Red Tec 12a is a propane based R12/R134 substitute that operates at a lower head pressure. They sell it up here to do-it-yourselfers because the proper refrigerants are only sold to and dispensed by licensed AC service people. As you mentioned, taking it to a qualified professional is the correct thing to do. Quote Link to comment Share on other sites More sharing options...
