P0301 after driving through 3 feet of water
auturner
2011 edge sel 129xxx miles. Drove it through some water in mississippi a month ago, since then im getting p0301 code- misfire on cylinder 1. changed coil and plugs. light went away for a few hours then came back flashing. drove it through 3 feet of water. no water in oil.
  • 1004ron changed the title to P0301 after driving through 3 feet of water
P0420 - catalyst system efficiency below threshold bank . this code is whats showing up now. got rid of the p0301. do i need to replace the catalytic converter? or is there any sensors or anything i can check or replace first? i have a obdii reader with live datastreaming but i am not mechanically inclined enough to look at the data streaming to be able to pin point what exact type of issue im having.
