66lincoln Posted July 1, 2020 Report Share Posted July 1, 2020 (edited) Vehicle 2015 Ford Edge Titanium, dual zone HVAC, 3.5L V6. Problem Driver side stuck on cold air and air not coming full force through all vents (as if the fan never spools up to it's highest speed on max-recirc). Diagnosis Forscan came up with these fault codes: B1081 Left Temperature Damper Motor failure and B1086 Air Distribution Damper Motor failure. Parts RockAuto has three Motorcraft modules/motors listed: (1) YH2022 (GS7Z19E616A, YH1906) Mode Door Motor controls which vents the air comes out of. (2) YH2023 (GS7Z19E616B, YH1905) Main Temperature Control Motor. (3) YH2024 (GS7Z19E616C, YH1907) Recirculation Door controls recirculate or fresh air option. Questions: 1. Do I only need to buy #1 for the driver side or do I need to buy a combination of these modules/motors? 2. Are the modules/motors replaceable without removing the entire dash? I'm a retiree so removing the glove box or an easy panel or two is doable for me, but not full dash removal and I'd like to avoid the cost of going to the dealer as much as possible. Thank you. /Paul Edited July 1, 2020 by 66lincoln Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted September 7, 2020 Report Share Posted September 7, 2020 (edited) Try a HVAC reset first. Press the climate control button, the defrost button and the power button at the same time. then press the climate control button again and it should be reset. Edited September 7, 2020 by enigma-2 1 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted September 7, 2020 Report Share Posted September 7, 2020 2015 factory manual may be of some help when it comes to replacing parts https://drive.google.com/drive/u/2/folders/1wBzOTmEZvCvnzvmTI470QBGyYX60xDBh Quote Link to comment Share on other sites More sharing options...
2015Edge2015 Posted August 7, 2023 Report Share Posted August 7, 2023 (edited) Does anyone know what B10 8313 code means? Also, which side os the actuator that controls the temperature for each side? Edited August 7, 2023 by 2015Edge2015 Quote Link to comment Share on other sites More sharing options...
