Elciteeve Posted June 28, 2020 Report Share Posted June 28, 2020 (edited) Has anyone replaced the seal on a 2013 edge se? Lookig to get a kit or list of parts needed. Thanks! Some people refer to it as the ptu seal. Edit - Doing some digging I'm seeing that there is an entire PTO unit that can be replaced. It's only $600.00 for an aftermarket or rebuilt part. I'm wondering if this would be easier / better. I've now come to find that the PTO / PTU is a common part to fail! What a joke! If I'm pulling the axles out to replace seals and so on it might be worth it to replace the entire PTU. The seal sets I've found range between $100.00 and $250.00 so for an extra few hundred or so it might just be worth it to replace the entire assembly. I don't want this to be an all weekend project though if I don't need it to be. I'm having hard shifting and figured the transmission was behaving like it was low on oil. Sure enough when I looked under the car there is oil leaking from the seals. I figured I'd replace the fluids and see what happened. Now I'm wondering if my unit has just gone bad, or even if it hasn't if I should get ahead of the problem before me or my wife are left stranded. I would have thought the rough shifting would be due to low ATF, but the ATF has no dip stick and I see no leaks, and the PTO is leaking on both sides. Any insight would be greatly appreciated! Thanks all! Edited June 30, 2020 by Elciteeve Quote Link to comment Share on other sites More sharing options...
