DrivingofftheEdge Posted June 23, 2020 Report Share Posted June 23, 2020 Has anyone put a BOV adapter on their 2.0? I cant find any that "fit". The have one that works on the fusion/escape and focus as well as f150 and mustang but nothing for the edge with a 2.0 liter. Quote Link to comment Share on other sites More sharing options...
Nick Halstead Posted June 24, 2020 Report Share Posted June 24, 2020 (edited) The focus one works. You have to remove passenger wheel. Though its not really worth the hassle Edited June 24, 2020 by Nick Halstead Quote Link to comment Share on other sites More sharing options...
DrivingofftheEdge Posted June 24, 2020 Author Report Share Posted June 24, 2020 Why do you have to remove the passenger wheel? Isnt the air bypass valve right under the oil pan? Quote Link to comment Share on other sites More sharing options...
Nick Halstead Posted June 24, 2020 Report Share Posted June 24, 2020 12 hours ago, DrivingofftheEdge said: Why do you have to remove the passenger wheel? Isnt the air bypass valve right under the oil pan? https://www.focusst.org/threads/rallysport-direct-installs-the-turbosmart-dual-port-bov-on-white-sheep.4929/ Quote Link to comment Share on other sites More sharing options...
DrivingofftheEdge Posted June 25, 2020 Author Report Share Posted June 25, 2020 A couple of things different. That's a focus pre-2015, not sure of the engine. The crossover pipe that goes from the intercooler to the inlet at the rear of the engine has the diverter valve on the bottom under the oil pan. I'll post some pics, I ordered the boomba racing adapter. Quote Link to comment Share on other sites More sharing options...
Nick Halstead Posted June 25, 2020 Report Share Posted June 25, 2020 (edited) these images are from a 2017 Edge 2.0 There's a video, but it's in my FB group. Def have to remove tire for easier access Edited June 25, 2020 by Nick Halstead Quote Link to comment Share on other sites More sharing options...
DrivingofftheEdge Posted June 25, 2020 Author Report Share Posted June 25, 2020 AWD? That looks different then where mine is. Quote Link to comment Share on other sites More sharing options...
DrivingofftheEdge Posted June 29, 2020 Author Report Share Posted June 29, 2020 Super easy, didnt remove the passenger wheel 2 Quote Link to comment Share on other sites More sharing options...
lildisco Posted June 30, 2020 Report Share Posted June 30, 2020 Ordered a Turbosmart from Summit Racing. We'll see how this goes. Wife's always a little jealous of my HKS in my CX7 Quote Link to comment Share on other sites More sharing options...
lildisco Posted July 1, 2020 Report Share Posted July 1, 2020 (edited) Welp, it bolts up, but there's an electrical connection on the bpv that's not on the new BPV. Assuming that it monitors boost, so no go for me on my 2016 fwd Edited July 1, 2020 by lildisco Quote Link to comment Share on other sites More sharing options...
Nick Halstead Posted July 2, 2020 Report Share Posted July 2, 2020 3 hours ago, lildisco said: Welp, it bolts up, but there's an electrical connection on the bpv that's not on the new BPV. Assuming that it monitors boost, so no go for me on my 2016 fwd Yours did not come with this piece? That plugs into the plug you unhooked? https://www.turbosmart.com/product/bov-cel-plug-ford-mustang-fiesta-ecoboost/ Quote Link to comment Share on other sites More sharing options...
lildisco Posted July 2, 2020 Report Share Posted July 2, 2020 negative. It also doesn't have anywhere for that vacuum line to go either Quote Link to comment Share on other sites More sharing options...
lildisco Posted July 2, 2020 Report Share Posted July 2, 2020 assuming that i need this one instead: https://www.turbosmart.com/product/kompact-em-bov-plumb-back-vr2/ Quote Link to comment Share on other sites More sharing options...
lildisco Posted July 2, 2020 Report Share Posted July 2, 2020 Just got off the phone with Turbosmart & they claim that the above part will not fit in the charge pipe as the mounting points are different. They suggest using the cheater plug mentioned above & running a vacuum line off the intake manifold. I'm not sure that i want to do this at the moment because the edge has been pretty reliable & don't want to mess that up. I do have a vacuum line that i use for the Catch Can, but not 100% sure how that's routed, so maybe i'll look into that before i return to Summit. Quote Link to comment Share on other sites More sharing options...
Nick Halstead Posted July 3, 2020 Report Share Posted July 3, 2020 7 hours ago, lildisco said: Just got off the phone with Turbosmart & they claim that the above part will not fit in the charge pipe as the mounting points are different. They suggest using the cheater plug mentioned above & running a vacuum line off the intake manifold. I'm not sure that i want to do this at the moment because the edge has been pretty reliable & don't want to mess that up. I do have a vacuum line that i use for the Catch Can, but not 100% sure how that's routed, so maybe i'll look into that before i return to Summit. believe all of us with a real BOV have a vacuum line ran to the intake manifold. did your kit not ship with anything but the BOV? mine came with vacuum lines, a T and the plug I linked Quote Link to comment Share on other sites More sharing options...
lildisco Posted July 3, 2020 Report Share Posted July 3, 2020 My CX7 came with one, this was supposed to be a direct swap or at least that was my understanding. I could do that, which probably would be fairly easy, but I'm a little uneasy taping into a vacuum line. I just got to look at where I spliced into a vacuum line for my Team RXP Catch Can & see if it's relatively easy to install. Plus spend the $40+ on a cheater plug Quote Link to comment Share on other sites More sharing options...
Ashen98 Posted January 15, 2021 Report Share Posted January 15, 2021 On 6/24/2020 at 8:21 PM, DrivingofftheEdge said: A couple of things different. That's a focus pre-2015, not sure of the engine. The crossover pipe that goes from the intercooler to the inlet at the rear of the engine has the diverter valve on the bottom under the oil pan. I'll post some pics, I ordered the boomba racing adapter. Could you share a link to where you acquired this one? My go to place for parts has been CJ pony Parts but they no longer list the adapters. Thanks!! Quote Link to comment Share on other sites More sharing options...
DrivingofftheEdge Posted January 15, 2021 Author Report Share Posted January 15, 2021 I got it at Boomba Racing. Quote Link to comment Share on other sites More sharing options...
Lessm723 Posted March 31, 2021 Report Share Posted March 31, 2021 Boomba racing works. Just put on this afternoon. Makes me smile every time I hear it lol. https://www.boombaracing.com/ford-ecoboost-blow-off-valve-adapter-bova-v1/ i have a 2017 2.0. Took 10 min to slap it on. Unscrew stock one put this on and stock on top. Easy peasy. Quote Link to comment Share on other sites More sharing options...
DrivingofftheEdge Posted March 31, 2021 Author Report Share Posted March 31, 2021 I put mine on about 6 months ago, maybe more. I love it but makes me wonder if that extra air its letting off instead of recirculating is taking some performance away. Quote Link to comment Share on other sites More sharing options...
EdgyJim Posted September 1, 2021 Report Share Posted September 1, 2021 On 3/31/2021 at 5:52 AM, DrivingofftheEdge said: I put mine on about 6 months ago, maybe more. I love it but makes me wonder if that extra air its letting off instead of recirculating is taking some performance away. It does, that if why they have the combo valve where you can adjust how much is vented to atmosphere vs recirculating -- which keeps the turbo from having to build up pressure again. I'm not too sure you will feel a difference since the throttle is closed and the air needs to go somewhere just not in to the throttle body. Quote Link to comment Share on other sites More sharing options...
EdgyJim Posted September 1, 2021 Report Share Posted September 1, 2021 On 3/30/2021 at 10:03 PM, Lessm723 said: Boomba racing works. Just put on this afternoon. Makes me smile every time I hear it lol. https://www.boombaracing.com/ford-ecoboost-blow-off-valve-adapter-bova-v1/ i have a 2017 2.0. Took 10 min to slap it on. Unscrew stock one put this on and stock on top. Easy peasy. Is that the only part I would need to order? Quote Link to comment Share on other sites More sharing options...
Lessm723 Posted September 2, 2021 Report Share Posted September 2, 2021 Yes only part. Just take of factory valve and put between. Quote Link to comment Share on other sites More sharing options...
EdgyJim Posted September 2, 2021 Report Share Posted September 2, 2021 Got it. It looks like you can get either and they would work, not sure I want to mess with how much is vented so I'm going with the simple solution. Quote Link to comment Share on other sites More sharing options...
Viperlead Posted July 2, 2023 Report Share Posted July 2, 2023 On 9/1/2021 at 1:25 PM, EdgyJim said: Is that the only part I would need to order? So you get any turbo lag from using the blow off valve? I was always told under 800hp to use a bypass valve Quote Link to comment Share on other sites More sharing options...
