jljbtm Posted January 16, 2023 Report Share Posted January 16, 2023 I read through all of these complaints of the rear gate not opening because my 2016 has a slightly different problem where it will open and close properly but now (lately) upon closing it automatically reopens and stays open I have to go and physically close it.? jack Quote Link to comment Share on other sites More sharing options...
Arbee Posted February 6, 2023 Report Share Posted February 6, 2023 Hi All, Recently, i have been experiencing some issues with the powerlift trunk. About a few weeks ago, it slowed down on open and close. When closing, it would sometimes not latch and then open slightly. It would open again when the exterior trunk open button is pressed. But, it would not close by pressing the button on the inside of the trunk door. I would have to manually close it. I am suspecting the powerlift struts and possibly motor. Any suggestions? As always, its very difficult to get clear answers from the UAE dealership. Its easier with this forums understanding. Thanks, Arbee Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted February 8, 2023 Report Share Posted February 8, 2023 Have you tried a manual open/close to test for binding? Havevyou tried lubing the hinges? Quote Link to comment Share on other sites More sharing options...
Arbee Posted February 8, 2023 Report Share Posted February 8, 2023 27 minutes ago, enigma-2 said: Have you tried a manual open/close to test for binding? Havevyou tried lubing the hinges? Manually, it opens and closes with no issues. Quote Link to comment Share on other sites More sharing options...
Haz Posted February 10, 2023 Report Share Posted February 10, 2023 Because your Edge is exhibiting several Power Liftgate symptoms -- change in open/close velocity; a sporadic failure to pulldown and/or latch; cargo area pushbutton opens but does not close while exterior pushbutton performs normally -- the best-first step may be to perform the Power Liftgate Initialization procedure, which involves de-powering the Rear Gate Trunk Module (RGTM)... Document download link> Power Liftgate Initialization - 2016 Edge Workshop Manual.pdf You will notice this RGTM de-powering can be done either by pulling the RGTM fuses or by disconnecting the Edge's battery. If you choose pulling fuses, there are two -- F76 in the Battery Junction Box (BJB) and F10 in the Body Control Module (BCM)... Battery Junction Box (BJB) Images Release the tabs. Lift and position the top part of the junction box aside. Body Control Module (BCM) Images de-powering Be aware that the alternative RGTM de-powering method -- Battery Disconnect procedure -- offers these cautions... NOTICE: Removing the negative battery ground cable at the LH strut tower will not disable the vehicle's electrical system. Failure to disconnect the battery cable from the battery post may cause component damage. NOTE: When the battery is disconnected and connected, some abnormal drive symptoms may occur while the vehicle relearns its adaptive strategy. The vehicle may need to be driven to allow the PCM to relearn the adaptive strategy values. Document download link> Battery Disconnect and Connect - General Procedures - 2016 Edge Workshop Manual.pdf The following Workshop Manual section provides a wonderful explanation of Power Liftgate operation in conjunction with the RGTM and other components... Document download link> Power Liftgate System - Description and Operation - 2016 Edge Workshop Manual.pdf Please report back on the outcome of the Power Liftgate Initialization procedure. Good luck! 2 Quote Link to comment Share on other sites More sharing options...
Arbee Posted February 13, 2023 Report Share Posted February 13, 2023 Thanks @Haz, I will report back soon. Quote Link to comment Share on other sites More sharing options...
edjunior Posted February 15, 2023 Report Share Posted February 15, 2023 That is an excellent write-up. I may be having some issues, but I haven't had the car long enough yet to really test it. It did do something funky yesterday, and my wife saw it on the screen, but I did not, and it was all good when I looked. Anyway, I'll keep watch on this to see how it went. Quote Link to comment Share on other sites More sharing options...
edwcler Posted December 12, 2023 Report Share Posted December 12, 2023 (edited) I have a 2019 Edge ST with a power liftgate. The other day, I was opening it when it was next to the garage door. Thought I had enough room, but didn't. I stopped the door with my hand, and it reversed, and I stopped it again and then it didn't move anymore. I closed the door by hand, and it latched. After that, It won't power open or close. The remote or button on the dash will unlatch the door, but the actuators won't work. I checked the 30A fuse in the engine compartment which was good. There seems to be another fuse in the passenger compartment, but there is no way I can get my hands in there to check the fuse, let alone pull it and replace it. I tried disconnecting the battery, and that didn't work either. Is there anything else I can check before taking it into the dealer$hip? Edited December 12, 2023 by edwcler Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted January 5, 2024 Report Share Posted January 5, 2024 (edited) See if this helps. One thing that can cause this is to manually close the liftgate, but not latch it. To reset the power liftgate: 1. Disconnect the battery for 20 seconds then, reconnect the battery. 2. Manually close and fully latch the liftgate. 3. Power open the liftgate by using the integrated keyhead transmitter, or the instrument panel control button. Note: If the power liftgate system is turned off in the message center, the system cannot be activated with the outside release handle or rear cargo area control button. The system will need to be turned on to resume operation with the outside release handle or rear cargo area control button. The power liftgate is still operational through the use of the remote entry transmitter and instrument panel button when the power liftgate is turned off in the message center.” Edited January 5, 2024 by enigma-2 Quote Link to comment Share on other sites More sharing options...
kruzr1 Posted January 6, 2024 Report Share Posted January 6, 2024 You might also need to set your opening height of the liftgate. Manually move the liftgate to the max opening height or wherever you want it. Then press and hold the open/close button until it beeps for confirmation. Hopefully this may be all it needs. I'm thinking it might've gotten confused? Quote Link to comment Share on other sites More sharing options...
Johnny22 Posted March 26, 2024 Report Share Posted March 26, 2024 Did you ever get this resolved? We are having the same issue....... Quote Link to comment Share on other sites More sharing options...
A2A Posted April 19, 2024 Report Share Posted April 19, 2024 I am also having the same issue. Exactly the same. Liftgate was hitting the garage door so I stopped it with my hand. Now it doesn’t work anymore. I tried the reset on the liftgate. It beeped but still doesn’t work. Seems like this should be easy to resolve….but how? Quote Link to comment Share on other sites More sharing options...
gonesail Posted May 7, 2024 Report Share Posted May 7, 2024 (edited) i was wondering what would happen if the liftgate collides with something .. like a concrete block wall? i kinda wish it was still manual like my 2011 edge. did you guys ever get this resolved?? is there a way to make it manual again?? Edited May 7, 2024 by gonesail Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted May 8, 2024 Report Share Posted May 8, 2024 Depend on how fast you were moving. I accidentally had the liftgate up and pulled into the garage. Top hit the bottom of the garage door. I was moving really slow and it didnt hurt the liftgate at all. (Made a hell of a thunk however.) If you hit a concrete wall, if it were still opening, I'd imagine the hatch would simply reverse when the hatch realized there was an object present. May scratch the paint however. To make it manual, you can just turn off the automatic function. On mine (Lincoln MKX), there's an on/off setting in the information center. When turned off, it must be opened and closed manually. Quote Link to comment Share on other sites More sharing options...
chenry Posted October 10, 2024 Report Share Posted October 10, 2024 My 2015 Ford Edge SEL liftgate works well but the issue is if while unloading you accidently get your foot under the sensor, it starts closing while you are bending into the back to get items. Even if the liftgate hits your back it will not stop closing and continues pressing down. My husband had to pull himself out as the pressure kept increasing. He scraped his back getting out and the door continued to close and then locked. This was very scary and dangerous. I would think it would operate like a garage door opener that if something was in the way it would stop and go back up. I called a Ford dealership to see if there were any recalls or reports of this happening and their only reply was no, but I could bring it in for a $200 diagnostic and then would get an estimate to fix it. Also, they would have to have my car for at least 5 days before they could do the diagnostic. Quote Link to comment Share on other sites More sharing options...
Connienut Posted October 27, 2024 Report Share Posted October 27, 2024 I have a 2019 Edge Titanium. the lift gate opened/closed a couple ties, then stopped, I have tried the battery disconnect trick, but still nothing. when we hit the button on the liftgate, the dash button, or the button on the remote, it does unlatch, but does not open/close automatically anymore. Any thoughts? Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted October 28, 2024 Report Share Posted October 28, 2024 (edited) This has been seen many times here in the forum. Any possibility you can run the codes? When you open the liftgate, it unlatches and then what happens? Does it make any kind of feeble attempt to raise or is it dead? If dead, my first suspect is your vehicle battery is getting weak and needs replacing. (#1 cause #1). If it tries to open and fails, try lifting the liftgate full open and see if it holds its position. If it doesn't, the pneumatic lift arms are getting weak and need replacing. (The motor lift needs the lift of the pneumatic lift arms to raise it the first 50% of the lift.) Any binding when opening manually? If the Hatch stays full open (or nearly full) the pneumatic lift arms are good and the liftgate module "could" be at fault. You'll need to have the dealer replace it as it needs programming. If the module is failing, it should set a BCM code. Edited October 28, 2024 by enigma-2 Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted October 28, 2024 Report Share Posted October 28, 2024 Check fuse #76 (30a) in the engine fuse box and fuse #10 (5 amp) in the interior fuse box. Both control the liftgate. Quote Link to comment Share on other sites More sharing options...
lordorion Posted November 7, 2024 Report Share Posted November 7, 2024 (edited) EDIT: my apologies for not searching for other threads about this issue. I’ve found a couple…feel free to ignore or redirect me! I’mhaving trouble with the liftgate on our Edge, been going on since 11/3. When pressing the button on the lift gate, the driver side will begin to lift, barely crack the seal, and then reclose itself. The passenger side doesn’t even look like it is even moving. The button on the dashboard doesn’t seem to work either. It has opened maybe a couple of times since then, but it is VERY intermittent/random. It did work once/twice using the kick sensor, then still did what I mentioned previously. I’ve tried all the tips/tricks mentioned here and elsewhere: checking/pulling fuses (all good fuses), disconnecting the battery cables for a few minutes, press and hold the tailgate buttons to try and reset it. I even tried resetting the opening height. Does anyone have any idea what it could possibly be? I’m not afraid of trying to fix it myself, if it’s possible. I was wondering if anyone could give me an idea on what else it could be or something else to try. thanks in advance Edited November 7, 2024 by lordorion 1 Quote Link to comment Share on other sites More sharing options...
bamabob Posted January 18 Report Share Posted January 18 Mine is doing the exact same thing today. Have you found a solution? Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted January 21 Report Share Posted January 21 (edited) On 1/18/2025 at 2:11 PM, bamabob said: Mine is doing the exact same thing today. Have you found a solution? There have been several faults listed in this thread. Can you elaborate as to exactly what your hatchback is doing (or not doing)? (BTW, how old is your cars battery? A weak battery can cause problems like described above.) Edited January 21 by enigma-2 Quote Link to comment Share on other sites More sharing options...
