omar302 Posted June 15, 2020 Report Share Posted June 15, 2020 (edited) Came upon an interesting article (posted in a thread in F150Forum) about Engine Oil for Turbocharged Direct Injection Engines which are increasingly being the normal nowadays. Which also applies to Ford Ecoboost line of engines. In short, there is now a new Engine Oil Standard, API SN Plus, SP, & GF6, which have been designed to reduce Low-Speed Pre-Ignition. Going Ford Edge Owners Manuals, it seems Ford switched to the API SN Plus in 2019. The Oil Specification WSS-M2C946-B1 (US part number 5W30-Q1SP) instead of the previous WSS-M2C946-A (XO-5W30-QSP). On MotorCraft website, it is also stated "This oil also meets WSS-M2C946-B1 and SN PLUS; therefore it can reduce oil derived low speed pre-ignition." So it would be recommended to check for the newer oils regardless of your Ecoboost Edge's year. Look for an oil that is API SN Plus, API SP, or GF6. Edited June 15, 2020 by omar302 1 Quote Link to comment Share on other sites More sharing options...
1004ron Posted June 15, 2020 Report Share Posted June 15, 2020 I've got a fair size stock of Mobil 1 that I buy when Costco runs the specials on the 6 qrt packs, and pleased to see it meets that spec. Not to forget the Mobil 1 mail in rebates that I get every year for the past 5 years. https://www.mobil.com/en-us/passenger-vehicle-lube/pds/gl-xx-mobil-1-5w30 Quote Link to comment Share on other sites More sharing options...
akirby Posted June 15, 2020 Report Share Posted June 15, 2020 (edited) Pennzoil Platinum full synthetic also meets api sn plus now. Edited June 15, 2020 by akirby Quote Link to comment Share on other sites More sharing options...
