Sledwrecker Posted June 8, 2020 Report Share Posted June 8, 2020 (edited) Forgive me if this is buried in the forum somewhere.. I've been reading for a couple hours and haven't found any posts with this same issue on a 2nd gen Edge Titanium. Case: 2018 Ford Edge Titanium with stock halogen H11 / 9005 halogen projector housings. When installing Xentec 35w HID kit w/o harness (plug-n-play) HIDs shut off immediately when vehicle is running. Details: Rough install of a Amazon Xentec 35w plug-n-play HID kit (no hardness) or canbus / cancelers. When the vehicle is off but ignition is in the on position the HIDs work perfectly. When you start the car (engine running) they shut off. You can turn the headlight switch off then on again and the HIDs come on for about 1/2 a second then shut off again. I did spend about two hours last night using forscan to change numerous values outlined in the forscan forums for a factory HID headlight swap but this made no difference to my particular issue. Disabling the DLRs through the dash's on screen menu made no change in behavior. Disabling DLRs with forscan made no difference either. I'm thinking it could possibly be canbus and I need cancelers or maybe with this particular model edge requires an HID relay harness? Edited June 8, 2020 by Sledwrecker Quote Link to comment Share on other sites More sharing options...
omar302 Posted June 8, 2020 Report Share Posted June 8, 2020 Did you install a relay and wire the HIDs to the battery or used only the stock wiring? I remember reading that such issues are only resolved by using a relay. Hopefully someone with better info will help. Quote Link to comment Share on other sites More sharing options...
Sledwrecker Posted June 8, 2020 Author Report Share Posted June 8, 2020 Hi Omar, no relay used but I’ll likely order one next. They are pretty inexpensive and should help protect the factory wiring during HID startup. Quote Link to comment Share on other sites More sharing options...
vega Posted June 8, 2020 Report Share Posted June 8, 2020 Yes, 2 things of note. One, you need the relay for it to work. Two, if you get flickering, you will need inline capacitors. Mine did flicker a lot. Quote Link to comment Share on other sites More sharing options...
