Stainless Steel Brake Lines
I'm trying to find Stainless Steel Brake Lines that will be a custom fit to my 2017 Ford Edge, or at the very least a universal Stainless Steel Brake Lines that will fit without any issues. All I found was some Stoptech stainless steel brake lines for a 2015 Ford edge,  but any ford edge year beyond 2015 i cant seem to find anywhere. Anyone know of a stainless steel brake lines that will fit my 2017 edge?
29 minutes ago, handfiler said:
Are you referring to the brake flex hoses that connect the calipers to the brake lines or the actual brake lines?
The line that connects to the caliper. Most kits come in 4 lines and should be around 17 inches to 18 inches long and has 10mm Banjo caliper fit thread for the 2017 edge
have you measured the stainless steel brake lines that you have found for the 2015? I ask because most if not all parts are compatible between 2015-1018.
I just had to email a few different places since they didn't post specs on websites. I checked summit raccing and they post from 2011 to 2015 ford edge with stoptech stainless steel brake lines. Seems odd to me since there isn't much visible difference between years in that area. Unless it's just the connector clamp that is different.
