ACM/FCIM bolt size?
I've had the need a few times to remove my stereo to run wiring behind the trim and have managed to lose some of the bolts to the ACM/FCIM.
Does anyone know what size these are? I can't locate that info online (so far).  I have a 2016 Edge SE 2.0L with the small screen.
So anyone else in this situation - I found the part #. This bolt is used in multiple places. Part # W707628-S424. They run anbout $0.75/ea.
From what I found online:
Glove Box Assembly Screw, Cluster Lens Screw, Cluster Assembly Screw, Receiver Screw, Display Unit Screw, AM/FM CD Screw, Catch Screw, Mount Bracket Screw, AM/FM Radio Screw, Satellite Radio Screw, Tray Screw, Passenger Air Bag Screw, Retainer Screw, Lower Column Cover Screw, Sun-Visor Screw, Spacer Screw, Floor Console Screw, Module Screw, Cluster Bezel Screw, Radio Bezel Screw, Radio Bezel Retainer Screw, Bracket Screw, Instrument Panel Retainer Screw, Upper Bracket Screw, Compartment Upper Bolt, Storage Compartment Screw, Center Bezel Screw, Heater Control Screw, Handle Screw, Column Cover Screw, Side Trim Screw, Coat Hook Screw, Instrument Cluster Screw, Front Dr Speaker Screw, Inst Panel Speaker Screw, Striker Screw, Console Screw, Bezel Screw, Passenger Air Bag Retainer Screw, Hinge Retainer Screw, Switch Panel Screw, Cluster Bezel Front Bolt, Console Base Retainer Screw, Upper Duct Screw, Glove Box Screw, HVAC Temperature Control Panel Screw, Instrument Panel Trim Panel Screw, Bulb Screw, Instrument Panel Screw, Upper Panel Screw, Headliner Screw, Instrument Panel Air Bag Screw, Sun Visor Holder Screw, Sun Visor Screw, GPS Navigation System Screw, Instrument Panel Lens Screw, Steering Column Cover Screw, Screw
